Keep losing video signal
1194 9 2016-12-14
GMG
Flight distance : 3632605 ft
From time to time I've lost video signal and this hasn't been a big issue, but as of today it's become routine.
I've just returned from flying the Mavic and after a minute or so, the picture would cut, even at close range. I found that if I unplugged, then replugged to cable into my phone, I'd get the image back, but after a minute or so, it'd disappear again.
The cable hasn't been used much (hey, the Mavics are brand new!) and there's no signs of stress on it.
I'm going to try using a standard Apple lightning cable from the USB port in the middle, bottom of the RC to the phone (I don't have a micro to lightning cable to try in the main port) and will report back, but was wondering if anyone else is having this issue and if there's any other likely explanation than a faulty cable (aside from being too far away, which isn't the issue here).
2016-12-14
GMG
Update on this one: I've had a close look at the DJI provided cable (micro-USB to Lightning) and found there's a kink in it. Of the clamps that pull out of the RC to hold the phone, the left one has crimped the cable, so this is a cautionary tale.  It's easily done and I've been online and the replacement cables cost >20€ not incl. postage!  I've gone ahead and bought standard 30 cm USB to Lightning cables and will plug in from the bottom of the RC moving forward.
2016-12-14
Heavysledz
Flight distance : 819491 ft
so did a different cable resolve all of the video cut out issues?
2016-12-14
Hi GMG, I'm wondering as well. Do you still have the video signal issue?
2016-12-14
Div14
Hi there,I started a thread about the same issue I was having with my iPhone 7 plus,the only way I could get it to work properly was using the iPhone USB cable,
I purchased a cable from amazon, 15 cm USB to 90 degree lightning cable fits & works perfect.
2016-12-15
GMG
DJI Mindy Posted at 2016-12-15 08:44
It seems to have, although I can't really test this, as it seems that DJI's about the only manufacturer of Micro-USB to Lightning cables, so can only test with the standard USB connector into the middle of the RC.    Annoyed, as the DJI cable is clearly a better fit and had I realised that the grip arm would trash the cable, I'd have paid more attention, especially given how expensive it would be to get a new one  (21€ + shipping)!
I think the design here can be improved in 2 ways:
1) Revisit how the channel for the cable runs as its so easy to damage the cable (from the micro USB to the connection point for the phone)...I'll be interested to see how many others have this issue over the coming months, if not weeks.
2) While you're at it allow a cutaway in the left side grip arm to allow users to access the home button on the iPhone.  Obviously the device has a huge proportion of iOS users and the home button is common across the Apple range.
Cheers!
2016-12-15
GMG
Div14 Posted at 2016-12-15 20:07
Can you post a link for that cable?  I've bought 2x 30cm Anker Cables, but your option sounds better, in case I need to order more in the future!
2016-12-15
Div14
GMG Posted at 2016-12-15 20:26
https://www.amazon.co.uk/gp/aw/s ... e=UTF8&k=Toways
2016-12-16
Div14
Someone on another thread has said that if you put your phone in airplane mode is fixes the problem with loss of picture while using
the supplied dji lightning cable.ive tried this at home & so far it seems to have solved the issue.
2016-12-21
MacIak
Flight distance : 3419 ft
Belgium
Im not sure if stated anywhere clearly but I personally always go into airplane mode when flying mavic (unless using WiFi for RC)
2016-12-21
