Battery error - unable to land - NO RTH - hovering with yellow
1663 20 2016-12-14
LukasBlecha
Flight distance : 577543 ft
Czechia
Few days ago I experienced really weird behavior. I took off, and then got a "battery error" warning and DISCONNECT. Mavic was hovering 2 meters above the grass with yellow flashing lights, unable to connect to controller or land in RTH mode. I was simply unable to land this thing. In app there was set "RTH when disconnect - NOT hover". Newest firmware 1.03, newest DJI Go 4 app, Galaxy S7 phone.
Here is a video:
Thank you SO MUCH for your help. Lukas
2016-12-14
Hi LukasBlecha, I'm not familiar with healthdrones. Could you please sync your flight records from DJI GO app and provide me with your DJI account email and the data this occurred?
Is the DJI account email the same as your forum email?
2016-12-14
LukasBlecha
Czechia
Hello Mindy.
2016-12-15
Anoniem
Flight distance : 70043 ft
LukasBlecha Posted at 2016-12-15 09:36
Hello Mindy. Yes, same email as here, flight logs synced. Also sending you original TXT logs of those problematic flights as attachment.
she is asking for your email that you are using at DJI forum, fastest way to work is to just type your email or send private message if possible. If you worry about spam, maybe type AT instead of @?
2016-12-15
LukasBlecha
Czechia
Today I was investigating why data loss happened again. Everything was OK for 15 minutes. THEN my DJI GO 4 app (in Galaxy S7) freeze and since that time, in the log there are a lot of data loss records  (Downlink data connection lost for 1.1 seconds).
I am sure it has something to do with the freezing and crashing DJI GO 4 app. It causes RC being in some "weird mode".
2016-12-15
GeForceFX-be
Belgium
So how were you able to land it in the end? Especially the second time when it was far from you? Just let the battery drain?
2016-12-15
LukasBlecha
Czechia
I was trying to get it connected, so restarted everything and after few minutes it connected again. Seems it has something to do with crashing of the app.
2016-12-16
LukasBlecha
Czechia
Today - again - after 15 minutes of OK flight - DJI GO 4 app frozen, so many "data loss" and no video. Had to land by visual only with RC. Going to test the old DJI GO app, this IS NOT POSSIBLE.
2016-12-16
Ex Machina
Flight distance : 1806362 ft
LukasBlecha Posted at 2016-12-16 21:26
http://healthydrones.com/main?flight=afdc262e749a74e216e22c9f97d25c7b&page_id=GENERALNotifications
Maybe obvious, but have you tried deleting the app and its files and reinstalling?
2016-12-16
fans92b36800
Flight distance : 1023182 ft
Very interested in the result. Same happened to me today.
2016-12-16
lildevilx
Flight distance : 264101 ft
odd... it happen to me today too... i had a good 10-15 min flight. When the mavic got to about 50 meters away,i then got
Cannot hover automatically now. Aircraft has been switch to A-mode. fly with caution
so i immediately try to fly back with LOS but a few seconds later i got "battery error" and "signal lost"
the mavic decided to RTH from the signal lost. The scary part was that the mavic was quite close to a tree, so as soon as it reconnected, i tried to cancel the auto land but before i could, the radio lost signal again not too sure what was happening... but the "battery error" does worry me quite a bit...
Any idea @DJI Mindy?
2016-12-16
MacIak
Flight distance : 3419 ft
Belgium
following thread...
2016-12-16
Mayoo
Flight distance : 299708 ft
Do you have any iOS device just to see if the Android App is the culprit ?
2016-12-16
Pallica
Flight distance : 149042 ft
Czechia
Hi all,, today i had the same problem after 4 min. flight, battery error, Signal Lost. Aircraft Returning Home luckily.
Before when i had previous firmware never happend to me,,, yesterday i upgraded to the latest 1.03 ...
Maybe problem is in the new firmware, what do you think ????
(or temperatures outside dropped near by zero °C, but battery had 20°C at minimum )
Flight records in attachment
DJIFlightRecord_2016-12-17_[17-35-54].rar
62.69 KB, Down times: 0
2016-12-17
LukasBlecha
Czechia
Ex Machina: Of course, I have clean re-installed the app... Several times...
Pallica: Please could you upload those records to healthydrones so we can check it out?
DJI GO 4 app is crashing like a crazy on Galaxy S7. :-/ After 15 minutes of OK flight, it starts to lag and freeze little bit, in a minute it is totally frozen and it crash, and since this time - signal loss problems start occure. Tried with the old DJI GO app as well, an same behaviour, even more crashes. DJI, please solve this problem asap.
2016-12-18
z4k4tt4ck
Flight distance : 535 ft
LukasBlecha Posted at 2016-12-18 20:58
I don't think the S7 is supported ? Its also not a problem for dji that their drone wont fly underwater because  under water flight is not supported .... guess its really your problem ... best to sort it out ....asap.
2016-12-18
LukasBlecha
Czechia
z4k4tt4ck: Previous model S6 is supported. S7 is Android flagship and not working with Mavic?! DJI has to be kidding.
2016-12-19
fansf0572733
Flight distance : 2098566 ft
Been flying with S7 Edge + Go app 4.0 here. No issues whatsoever!!
2016-12-19
c_future
Austria
Hi
Maybe you want to have a look at my thread: http://forum.dji.com/forum.php?mod=viewthread&tid=74768&page=3&mobile=2#pid606315
Your Case Sounds similar
But I captured all the logs
2016-12-19
LukasBlecha
Czechia
Today - 12 minutes of OK flight. Then, DJI GO 4 app on my Galaxy S7 became irresponsive, then frozen and crash. Connection betweet RC and aircraft was without problems. Caching of video stream turned OFF.
Anyone similar problems on S7?
2016-12-21
c_future
Austria
btw - what i wanted you to ask..  do you have just one battery or do you have the same issues with another one as well?
so far, I had those with the same batt.
bty - using an one plus one 3 -- no issues with the app itself sofar.
2016-12-21
