P4 pro jerk frame
12345678Next >
17232 310 2016-12-14
buxdronex
Flight distance : 2100013 ft
During 4K 60fps and 30 fps video recording the camera jerks and the videos are unusable.
I also used different sandisk ultra microsd cards and the jerking is still there:
2016-12-14
jetforce
Denmark
Witch microsd cards did you try ?
2016-12-14
buxdronex
jetforce Posted at 2016-12-14 21:16
sandisk ultra 64 gb, sandisk ultra 32 gb, samsung pro 64gb
2016-12-14
Geebax
The SD card is not the issue, but in any event for best performance you should be using the Sandisk Extreme or Extreme Pro series, the Ultra series is borderline slow. The effect I am seeing has nothing to do with the recording, it appears to be a glitch in editing, what did you use to edit the footage?
2016-12-14
buxdronex
Geebax Posted at 2016-12-14 22:34
The problem is seen in the original videos which have then been cut to create a short clip.
micros are ok
Dji: Supported SD Cards Micro SD, Max Capacity: 128GB.
Write speed ≥15MB/s, class 10 or UHS-1 rating required
2016-12-15
Geebax
buxdronex Posted at 2016-12-15 19:23
micros are ok
The Sandisk Ultra series have been found by other users to be just on the border of being fast venough. The DJI rating is confusing because what is important is not the manfacturers claimed rating, but the sustained write speed.
In any event, the card will not be causing the problem you are seeing, there is something else happening here. In your short clip, I saw the image skip back one or two frames, and that cannot happen in the camera. This is why I asked how you edited it.
2016-12-15
buxdronex
Repeat: the problem is in original footage in any clips in different ad cards: Sandisk Ultra, original from dji, Samsung pro. Do you have understand? The problem is before editing!!!!!! Anyway final cut x pro and iMac 5k top configured
2016-12-15
DJI Natalia
Flight distance : 318 ft
Would you please upload the original video directly from the SD card to dropbox without edition, then provide us the link?
We'd like to help you check it.
2016-12-15
buxdronex
I think that the problem isn't the camera but the bad impulse that create the jerk on the gimball
2016-12-15
Ange1walk
Flight distance : 30305 ft
Austria
Just to chime in on MicroSD Cards:
A SanDisk ULTRA Class 10 Speed Class (U1) UHS-I will be bad to use with the P4PRO. It has a MINIMUM write speed of 10MB/s, but 100Mpbs on what the P4PRO is capable of = 100/8 = 12.5 MB/s.
So you would need a SanDisk Extreme Pro Class 10 Speed Class (U3) UHS-I. Which writes at a MINIMUM of 30 MB/s.
2016-12-15
buxdronex
I know, but with the original 16gb microsd cards (in the packaging of p4pro) and Samsung pro+ microsd card the problem is the same. Isn't a lost or bad frame, it's a rapid jerk of the gimball.
2016-12-15
RichardHurst
Banned
Flight distance : 2342808 ft
2016-12-15
buxdronex
RichardHurst Posted at 2016-12-15 17:01
Whilst this could be a write speed to the SD card issue it does also look like it's either skipping a frame or the gimbal is moving/flicking briefly although I've never heard of that before
Yes is a fast movement of the gimball, my p4pro have the same problem of your first (i remember). the engine of the gimball have a metallic noise, isn't a good copy
2016-12-15
Chest Rockwell
I have the EXACT same issue with mine.  I'm glad I'm not the only one.  The jerky video exists in the original file straight from the SD card (I am using SanDisk 64GB Extreme Plus).  It's extremely annoying.
I bought two (P4P and P4P+, to see if I preferred the new controller/screen or not).  The first one started having this problem frequently.  It's been cold so I've only flown once with the P4P+, no jerkiness in the video on the first flight.
It seems to me to be a gimbal issue, as far as I can tell.  The camera jerks quickly and resets.
Any word from DJI on this?
2016-12-15
buxdronex
DJI Natalia Posted at 2016-12-15 13:35
Would you please upload the original video directly from the SD card, upload it to dropbox without edition, then provide us the link?
Today I upload the original video if Dropbox accept the big size
2016-12-15
Geebax
buxdronex Posted at 2016-12-15 22:21
Hey, people here are trying to understand and help you with this issue. Keep your manners under control.
2016-12-16
buxdronex
Geebax Posted at 2016-12-16 09:41
Sorry, I really... I didn't mean to.
2016-12-16
buxdronex
Hello Natalia, my dropbox have 2Gb, the original footage is 4Gb, if you want I cut in two parts with quicktime, no editing.
2016-12-16
DJI Natalia
buxdronex Posted at 2016-12-16 18:17
That's will be appreciated, please let me know the link once it's done, thanks.
2016-12-16
buxdronex
DJI Natalia Posted at 2016-12-16 12:14
Hello Natalia, the original footage https://www.dropbox.com/s/x034g79x1y3ysik/DJI_0007.mov?dl=0
4 jerk at:
0,15
1,02
1,11
1,27
2016-12-16
buxdronex
Chest Rockwell Posted at 2016-12-16 06:22
Do you have check the jerk on p4pro+ after the first fly?
2016-12-17
Geebax
There is a thread on here where the OP reports a twitch in the gimbal when he takes a still shot, perhaps the same thing can happen at other times.
2016-12-17
DJI Natalia
NKars Posted at 2016-12-17 23:11
I have more a less the same problem..
Phantom 4 pro plus..
version 203
I downloaded the file you uploaded, unfortunately, I could not open it.
Would you please try again to upload to a dropbox without edition? thanks.
2016-12-17
NKars
Flight distance : 834117 ft
DJI Natalia Posted at 2016-12-18 08:19
I remove the file and the post...
It has to do with the refresh rate of the PC...
for windows 10 it is here
http://quehow.com/how-to-change- ... indows-10/4531.html
2016-12-18
DJI Natalia
buxdronex Posted at 2016-12-17 05:18
4 jerk at:
0,15
We do suggest you send it in for further evaluation by our engineers, sorry for the inconvenience caused.
Please send an e-mail with the subject "Forum Support" to support@dji.com and include the following information, we'll create a case for you:
SN:
Brief Description of your Issue:
Country:
Full Name:
Email Address:
Phone Number:
Shipping Address:
Zip Code:
Link to your case on Forum:
2016-12-18
DJI Natalia
Chest Rockwell Posted at 2016-12-16 13:22
Chest, sorry for the issue.
May I know have you tested it again in an suitable environment? The problems persist for the original videos, right?
Could you please upload a video for us?
2016-12-18
Chest Rockwell
DJI Natalia Posted at 2016-12-18 22:41
Hello Natalia,
I took my P4P+ for its second flight today.  I did get at least one "jerk frame" in my tests.  It was fairly windy today, for what it's worth.  I haven't had as many of these instances as with my original P4P, but having this happen at all is frustrating.  Hopefully it's something that can be fixed.
Here is a link to an example -- this is the original file, straight out of the Sandisk 64GB Extreme Plus card.  The issue happens around 21 or 22 seconds in.  It looks to me like a gimbal issue, like it jerks and quickly resets.  But these are my first drones so I can't say for sure.  Please let me know if there is anything else that I can provide:  https://drive.google.com/open?id=0BwVQH0uN5u-2MVFDd3BoWHFOdms
2016-12-18
DJI Natalia
Chest Rockwell Posted at 2016-12-19 15:02
Hello Natalia,
Thank, I've transferred the video to our engineers for evaluation, will get back to you if i get any news, thanks for your support again.
2016-12-18
buxdronex
DJI Natalia Posted at 2016-12-19 04:37
Please send an e-mail with the subject "Forum Support" to  and include the following information, we'll create a case for you:
SN:
I have an ongoing assistance procedure, I sent you the video hoping that it could be helpful in solving the problem
2016-12-19
kykphantom
Flight distance : 5892388 ft
Cyprus
I just wanted to say that I have the same problem with P4P.
2016-12-19
Chest Rockwell
DJI Natalia Posted at 2016-12-19 02:28
Thank you, Natalia.  I look forward to hearing their thoughts.
2016-12-19
DJI Natalia
Chest Rockwell Posted at 2016-12-20 13:43
We tried several time on different PCs but failed to download the video.
Would you please cut it and upload a smaller one, and do not edit it, thank you so much.
2016-12-20
DJI Natalia
4 jerk at:
0,15
We tried several times to download your video, but it crashed before we got it every time.
Maybe it's too large, would you please cut it and upload a smaller one?
Very sorry for the inconvenience caused.
2016-12-20
Chest Rockwell
DJI Natalia Posted at 2016-12-20 05:17
Sure, I can try to do that tonight - I'm at work right now.
2016-12-20
buxdronex
DJI Natalia Posted at 2016-12-20 11:17
I try an another upload
2016-12-20
fans4c5e3b97
Flight distance : 753163 ft
my video is also jumping, kinda like it has a zoom lens, in and out
2016-12-20
Chest Rockwell
Hello Natalia,
I have 3 examples for you that I have uploaded in smaller files.  These are original files, trimmed down in size per your request.  I have verified that the trimmed files show the exact same effect as the original files.
The first two examples are with my original P4P, at 60fps.  Both show the same issue where the frame seems to skip or something.
The third example is with my newest drone, the P4P+, which is the one I was hoping to keep (this one is 30fps).  This is a more severe gimbal twist type affect.
Please let me know what your team thinks after reviewing the files.
2016-12-20
DJI Natalia
buxdronex Posted at 2016-12-21 05:35
Please provide us the new link again, thanks.
2016-12-21
DJI Natalia
Chest Rockwell Posted at 2016-12-21 13:15
Hello Natalia,
The videos have been evaluated, the gimbal reaches to it's limitation when you push the sticks very quickly, as a result, the parameters are back to default, then you will see the issue in the videos.
2016-12-21
Chest Rockwell
DJI Natalia Posted at 2016-12-21 06:01
Thank you Natalia.
That does make sense for the P4P+ video I uploaded, because I was at the end of a move and I probably let the sticks go quickly.  So I can see that happening.
However, the other two from my original P4P happened mid movement with no quick stick movements.  They appear to me to be more like video frame errors as opposed to gimbal issues.  And I think they look more similar to the OP's original post as well.  I don't think I've seen that yet on my P4P+, which I think is the one I'm going to keep.  Hopefully it stays that way.
Thank you again for the help.
2016-12-21
12345678Next >
