RichJ53
Flight distance : 1837356 ft
This is taken from the new Inspire 2 manual. You can turn it on manually or by using the Go App
Rich
Heating the Battery
Manual Heating: When the battery is powered off, press and hold the power button for 3 seconds to
initiate the battery to warm up manually.
The battery will start to warm up when the temperature is below 59℉(15℃)with the LED1&2 and
LED3&4 blinking alternatively. The temperature of the battery will stop increasing when it reaches
68℉(20℃).
The temperature of the battery will be between 59°-68℉(15°-20℃)when it is above 59℉(15℃)with
the LED1 and LED4 blinking alternatively, lasting for approximately 30 minutes. And then it will be
powered off automatically.
Auto Heating: Insert the batteries into the aircraft and power on. When the temperature of the
battery is below 59℉(15℃), the battery will warm up automatically, and you may check the LED for
current
power level.
Using the Battery
INSPIRE 2 User Manual
Low Temperature Notice:
1. The performance of the intelligent Flight Battery is significantly reduced when flying in a low
temperature environments (those with air temperatures below 5℃). Ensure that the battery is fully
charged and the cell voltage is at 4.35 V before each flight.
2. If the DJI GO 4 app displays the “Critical Low Battery Level Warning” when flying in low
temperature environments, stop flying and land the aircraft immediately. You will still be able to
control the aircraft’s movement when this warning is triggered.
3. In extremely cold weather, the battery temperature will continuously decrease even it has
heating function. In such case, the battery capacity will slump with the flight time sharply
reduce.
4. To ensure optimum performance, keep the Intelligent Flight Battery’s core temperature above 20℃
when in use.
20℃ when in use.
5. Battery insulation paste is available for you to use.
