Heyandy
Flight distance : 413009 ft
I have used Autopilot when I had my Phantom 3 Pro and will continue to use with Mavic...
Here are my top reasons in no particular order:- I have a friend that also has a Phantom 3 and Autopilot. You can setup "Airspace" and now see each other's drone in your app. This allows things like letting Autopilot follow the other drone. You can let Autopilot do ALL the work, or you can take over control of the gimble, height, distance, etc.
- You can setup really cool, and complex, flight videos. Autopilot does not use the built in DJI waypoint system, instead it "flies" the drone realtime. This allows you to setup trigger points independant of waypoints for videos. i.e. you get to first plan your flight route, then you get to plan what the drone is aiming the camera at...
- Their 360 degree pano's work great
With that said, start out with the basics!!! Their are so many options that if you try and figure them all out at once you will get lost. It took me about 3 months to really start getting good at using it and really taking advantage of many features, and I haven't touch some to this date!
