PgyTech ND filter can't pass gimbal initializing
12Next >
7181 50 2016-12-28
Mr Hayato
Flight distance : 781299 ft
Here is my test video. I have push end enough and try many time still can't pass initializing
The seller said i need to push more 0.2mm to balance the filter. I don't think this 0.2mm will affect so much.
PGY filter is more thick at least 2-3mm between the gimbal. The same problem on my friends too.
I leave a comment on PGY youtube channel. They told me to send a email to their support but no one reply.
Luckly i just bought only one ND16 filter. I would like to try Taco or wait DJI offical ND filter.
2016-12-28
Skyhawk
I wish I had seen this post about 5 hours ago as I just purchased a PGY filter kit.
2016-12-29
ColoradoBob
Flight distance : 1601690 ft
I have the Taco RC Multi-coated filters and they let the gimbal fully initialize... Slow delivery though and they don't have a polarizer
2016-12-29
Skyhawk
ColoradoBob Posted at 2016-12-29 05:20
I can live without a CPL for now and I will most likely ended up going for a TACO-RC kit if the PGY don't do as they say which by the looks of it they don't.
2016-12-29
DaveAus
Flight distance : 100807 ft
New Zealand
I bought the Taco RC kit. No problems and filter do a great job.
2016-12-29
Petroboy
Flight distance : 3681 ft
Interesting.  Here's my video of a PGYTech filter on the lens during the gimbal startup.  There are no restrictions going on but notice the startup movements are different than in your video.  The gimbal doesn't make the tilt to the left like yours did.  Does the gimbal initialize differently at different times?
EDIT:  Sorry, but I can't get the video to attach properly.  My point was it seems that when I tried the gimbal startup, the gimbal moved freely but didn't swing hard to the left near the end where the contact was made.  Anyhoo, I still haven't had weather to allow me to actually try out the filters yet, but for me, the gimbal seems to initialize freely with the filter on the lens.
2016-12-29
Skyhawk
Petroboy Posted at 2016-12-29 16:45
Interesting.  Here's my video of a PGYTech filter on the lens during the gimbal startup.  There are no restrictions going on but notice the startup movements are different than in your video.  The gimbal doesn't make the tilt to the left like yours did.  Does the gimbal initialize differently at different times?  Sorry for the feedback noise.
C:\Users\Halward\Videos\Drone videos\IMG_1143.MOV
I was wondering about this cause I noticed on all the youtube video's I watched on ND filters on the Mavic and none of them did the startup routine as shown in the OP video.
2016-12-29
Petroboy
Skyhawk Posted at 2016-12-29 16:56
I don't think that any of the filter brands would be able to pass that swing to the left like in the OP's video.  They do need to be pushed on all the way however, as the tolerances are very close.
Just noticed also that the prop arms are closed in the OP video, whereas I had my Mavic fully extended.  Would this make any difference?
2016-12-29
Mr. Hayato
Skyhawk Posted at 2016-12-29 04:46
You should refund
2016-12-29
RichJ53
Flight distance : 1837356 ft
Sorry to hear this. I was hoping they would work on the Mavic... Do you think it is a weight issue? or is it hitting something?
What is the material of the lens, plastic or rubberized plastic?
Rich
2016-12-29
Mr. Hayato
Could you mind to share you video again? I find some videos on youtube. The gimbal check tilt left too.
I shoot this video without PGYtech ND on boxing day. It is 100% no problem.
You can check in other thread. Some guys have problem too.
http://forum.dji.com/thread-73625-1-2.html
2016-12-29
Mr. Hayato
RichJ53 Posted at 2016-12-29 17:56
The weight should be fine. It's only 1.3g.
2016-12-29
Petroboy
Post delete
2016-12-29
RichJ53
your video is not working for me?
Rich
2016-12-29
RichJ53
Mr. Hayato Posted at 2016-12-29 18:21
okay, I was just thinking out loud
Let us know if you come up with a solution... did you try starting up the Mavic and then carefully putting on the filter?
Rich
2016-12-29
Mr. Hayato
Could you mind upload to youtube?
2016-12-29
Petroboy
Mr. Hayato Posted at 2016-12-29 20:12
See if this works?  Having technical troubles tonight.
2016-12-29
Mr. Hayato
Petroboy Posted at 2016-12-29 21:19
https://vimeo.com/197477577
Thanks a lot. It looks great.
What is your firmware version? Maybe the latest firmware has less movement when gimbal check.
2016-12-29
Petroboy
Mr. Hayato Posted at 2016-12-29 21:32
This was filmed with the last firmware version before the most recent one that just came out.
2016-12-29
Mr. Hayato
After updated to latest firmware. The gimbal movement is less than before. But still can't pass the gimbal check.
2016-12-30
Miok
Same problem here, just receive it and after 12 tries I give up too...
done exactly like in the installation vidéo http://forum.dji.com/thread-78414-1-1.html but there's no way to pass the gimbal check
got the latest firmware.
2017-1-2
too fly
I had the same problem with the Polar filters.  You have to turn the drone on, let it run it's calibration, then put the filter on the drone (a dodgy proposal, but it works).  Polar has a "cinema" series of ND filters that is supposed to fix the problem.  They come out January 10.  Polar is offering an upgrade for a small fee.
2017-1-2
Miok
Hope PGYtech will do it too
2017-1-2
QuanthonyTrang
Flight distance : 419980 ft
Can people post their firmware please.
Mine is .29 firmware and my PGY initialise fine.
Could there be additional initialisation checks in the later or earlier firmwares?? I dont recall, but my initialisation does NOT look left or right at the end of initialisation.
And make sure the mavic is not on portrait mode.
2017-1-2
Mr. Hayato
QuanthonyTrang Posted at 2017-1-2 14:33
I have try 1.29, 1.30, 1.32。1.29 will look left right when initial。After 1.30 they doesn't. You can check my second video.
2017-1-2
Mr. Hayato
Miok Posted at 2017-1-2 12:24
Which ND filter do you have? ND 8? ND 16 or ND pack?
2017-1-2
QuanthonyTrang
There could be a weight/motor issue with your gimbal.
I noticed your initialises differently without the ND filters.
Is there any warnings on your screen? Has it been in a crash? Is gimbal mounted correctly?
2017-1-2
Miok
Got the ND8 and the ND16
2017-1-2
too fly
Miok Posted at 2017-1-2 23:48
Turn the Mavic Pro on (let it initialize), then put the filter on the drone.  It should work fine.
2017-1-3
Mr. Hayato
QuanthonyTrang Posted at 2017-1-2 20:04
The above video attached Taco ND filter(@3:20). Gimbal initial is completely same as mine.
I shooted a hundred video and photo. No warning, No Shaking, No Jello.
I don't think my Mavic has problem. You can check other thread they have same problem too.
In PGY installation demo, someone leave message too.
Do you think we all have a problem Mavic? I don't think so. lol
2017-1-3
QuanthonyTrang
too fly Posted at 2017-1-3 00:13
But thats not as advertised.
The PGY are designed to be left on.
2017-1-6
too fly
QuanthonyTrang Posted at 2017-1-6 20:44
I get it.  I had the same issue with the Polar set, as I said.  But this is a solution that actually solves the problem and gets your drone in the air with a filter.
2017-1-6
creep
Flight distance : 6072713 ft
Russia
Today I get PGYTECH ND 4, 8, 16, 32 set filters and CPL filter, and every filter can't pass initializing. I check it several times
2017-1-9
Watty2000
Flight distance : 1074301 ft
Yeah, my PgyTech ND8 does the same. Managed to get the gimbal to initialise a couple of times by twisting the filter into the camera before powering on but even then, the next time I power on, it would mostly fail.
2017-1-9
creep
Russia
Check my video
I also found that PGYTECH glass glued crooked
2017-1-9
m1xzg
I've just received the ND8 filter from PGY and the same thing, mine jams and fails initialization.  I bought it because I was under the impression it would work correct.  Glad I only ordered one filter.
2017-1-9
Mr. Hayato
Same as my video. Everyone just told me you are wrong installation. Your gimbal have problem. NOT the filter problem. lol
2017-1-9
Mr. Hayato
m1xzg Posted at 2017-1-9 12:01
Lucky you. I got ND16 only too. Could you mind to post a testing video too?
2017-1-9
Mr. Hayato
Watty2000 Posted at 2017-1-9 06:56
I guess PGY filter have quality problem.
2017-1-9
stratosHD
Flight distance : 1231280 ft
I order them as well. i dont even know where is the delivery at. They gave me a tracking number and a shipping company but still, the number doesn't even produce any result. I think i will wait for one more week else will open a dispute with Paypal
2017-1-9
12Next >
