P4P+ Not saving shooting settings?
1599 18 2017-1-3
kingstonphoto
Flight distance : 160197 ft
I might be a newb but for whatever reason everytime i start up the drone and controller its not reverting to my prefered settings when you turn everything off and go back in do you have to change the shooting seettings everytime?
2017-1-3
Labroides
Flight distance : 9991457 ft
Unlike earlier Phantoms, the P4pro saves most but not all camera settings between flights.
Perhaps DJI will fix this in a future firmware update.
2017-1-3
PliciPleosc
Flight distance : 100226 ft
Romania
I can confirm some settings always revert back to original when you turn it off.
2017-1-3
Rob8888
New Zealand
It would be tremendous if DJI decided to retain ALL shooting settings between flights.  Please consider my vote!
2017-1-3
kingstonphoto
Rob8888 Posted at 2017-1-3 19:19
YES or at least save settings to revert back to them faster
2017-1-3
theGrindLab.com
Flight distance : 1375846 ft
What the heck?! Was this done intentionally or is this a bug?
2017-1-4
gt3rs
Flight distance : 280056 ft
Switzerland
+1 it should keep the last settings. Sometime even changing fly mode seems to change camera settings. Also if you have used the gentle control settings it then switch back to the normal....
2017-1-4
trance728-
Flight distance : 298048 ft
gt3rs Posted at 2017-1-4 13:48
Aren't the gentle control changes only affecting the tripod mode?
2017-1-4
WYHSniper1007
Flight distance : 1003822 ft
It's wired perhap they will fix it in the future
2017-1-4
gt3rs
Switzerland
trance728- Posted at 2017-1-4 14:37
Not sure, according to this it seems not:
According to DJI support on the EXP settings screen I should be able to switch to 'Gentle' mode, and those settings are not linked to tripod mode (supposedly), they take effect when you switch to them on that screen.
Also from my quick test I had the impression that it was in use in all modes but sports. Unfortunately today the wind is at >80 km/h so no test possible.
2017-1-5
MrWhite
Flight distance : 272 ft
I also had this problem but after updating my remote's firmware on 1/5/16 the problem is no longer. However, notice how close the back arrow is to the highest, largest screen size as I accidentally touched it when backing out therefor setting the screen size.
2017-1-6
mindframe
i'm confused,  does the remote firmware update separately from the craft?   i'm on the pro+ and only see one firmware update button in the menu.  Or do I actually have to plug the craft in to update?
2017-1-6
PhantomPhil
Flight distance : 44731 ft
mindframe Posted at 2017-1-6 19:00
Yes, the remote firmware update on the P4P+ is separate from the craft. To update the firmware in the craft use DJI Assistant 2 on your PC and using the supplied USB cable plug craft into PC. Good luck.
2017-1-6
kingstonphoto
I find this to be true as well
2017-1-9
kingstonphoto
going to try this update, didn't know there was one..
2017-1-9
kingstonphoto
Updated my P4P+ and still losing settings
2017-1-16
Grizz 1
Flight distance : 120066 ft
kingstonphoto Posted at 2017-1-16 09:01
same here Kingston, had to do it all over again today, this is getting old.
2017-1-16
fansf4342166
Flight distance : 322 ft
Same here.  I'm a photographer who's a newbie to drone photography but am totally flummoxed by the way most (but not all) of my settings for still photos and movies are changed to default every time I switch off the machine, or change an autoflying mode.  This is ridiculous!  It seems almost as if the P4P+ has been designed to maximize the flying experience while not giving a hoot about the camera.
2017-5-28
Nimuie
Flight distance : 14003 ft
Hi All!
I might have the same problem - my stick setting always revert to Mode 2 after the last update. Since day 1 I used mode 3 without problems. after the last update that setting keeps changing reverting after power off
Any ideas?
Cheers
2018-10-21
