Propeller Jammed on Inspire 2. My problem solved see modification.
123Next >
10226 101 2017-1-4
Arrow1969
Flight distance : 400577 ft
Hi
Received my Inspire 2 yesterday been out test flying it today have had difficulty getting one of the propellers off one with a white dot this morning went flying again this afternoon now it won't come off at all its completely jammed.
Any ideas DJI-Jamie  ????
2017-1-4
Titomix
Hey! I received my Inspire 2 today and I have the same issue, the white ones are impossible to put it or when you achieve it, is imposible to get off :-/
2017-1-4
Donnie Stugots
Flight distance : 3636782 ft
Titomix Posted at 2017-1-4 09:56
I have heard this on a couple of threads now , sounds like something out of tolerance . They also had the same problems on the white props and locks .
donnie
2017-1-4
Titomix
Donnie Stugots Posted at 2017-1-4 10:00
donnie
Good work DJI... $4K and two months waiting and the propellors works bad... *applause*
2017-1-4
Donnie Stugots
Titomix Posted at 2017-1-4 10:16
You just have to wonder how these things could have been missed during testing and dealer distribution .
donnie
2017-1-4
Titomix
Donnie Stugots Posted at 2017-1-4 10:21
donnie
Is very disgusting, two Inspire 2 delivered this week in the forum and all with the same problem.
Is funny how I can't transport my new Inspire 2 because one propeller is stuck :-)
2017-1-4
Robin UAV
I'm sorry for you guys, but I'm happy I didn't jumped in and got the I2...
I really wonder how does things slip the QA tests!?!
2017-1-4
Aeromirage
Flight distance : 1778045 ft
In the rush to develop new products obviously things are being overlooked.
Beta testers used to be compensated for their efforts.............
2017-1-4
Farnk666
Flight distance : 1711394 ft
Settle down guys, they will sort it out given time.
This is the first shipment of a new product from DJI - there are ALWAYS issues. You all know this.
At least this time it is a problem with props staying on - when the Inspire 1 was launched it was exactly the opposite problem and many aircraft hit the deck hard.
Give them a good 6 months to stabilise the manufacturing and app/firmware QA. It will be golden after then.
2017-1-4
RichJ53
Flight distance : 1837356 ft
Well I am not DJI Jamie, but I have some thoughts. The tolerance must be pretty tight on the I2. I know we had some loose red prop hubs on the I1 but never tight.
I wonder if it has to do with the temperature? Is it really cold when you are putting the props on? Try putting the Inspire into a warm room and see if the prop comes off better. This could at least tell us the prop hubs are out of tolerance.
The Inspire 2 comes with spare prop hubs, that might worth trying also.
Sorry for the trouble and hang in there
Rich
2017-1-4
RichJ53
Aeromirage Posted at 2017-1-4 15:31
Just the million plus YouTubers get the prize now it seems.  Hard to make that list
DJI must have some supplier issues, we have seen this before when the supplies are tight
Rich
2017-1-4
Arrow1969
RichJ53 Posted at 2017-1-4 22:21
Hi Rich,
Yes I thought it might have been temperature I brought it indoors and let it warm up made no difference.
You write with tolerances our tights havering looked at it I think it's release mechanism it appears to be sticking.
2017-1-4
Arrow1969
Farnk666 Posted at 2017-1-4 21:41
Totally agree with you Farnk666,
There are always teething problems they will get sorted out it doesn't bother me in the least have emails DJI support will let you know what they say.
Tony
2017-1-4
Arrow1969
I think the problem is the white dotted propellers, have checked the mechanism on all the motors and they all work fine.
I think this is slight difference in the mouldings the red dotted ones appear to go on slightly easier.
I have a another inspired 2 being delivered later this week will check that one.
2017-1-4
Titomix
I'm in the South of Spain, 20º outside now and 15º indoor.
I try to apply air with a dryer and I have achieved it. Mystery.
I go to try change the QuickRelease System with the repairs ones includes in the box and try the other propellers pack.
Stay tuned....
2017-1-5
Titomix
I don't think this problem get solved with a firmware update
2017-1-5
Donnie Stugots
That is why I waited , I want  the little bugs to be worked out , If this is the biggest problem with it  then it should be a great machine .  Like I think Rich said , more than likely a supplier did not have his tolerances within spec.  You would still think someone would have caught it .
Cheers
donnie
2017-1-5
Cougar1
Flight distance : 924393 ft
Rich, Just got my I2 and can confirm there is a slight problem with one of the white props. Nothing to bad and seems fully workable just a bit stiffer then the other 3. Taken mine off and putting them back on several times, not concerned (at least for myself), seems very much the same issue as we bad on the other props/hubs before and think they will ease with use.
2017-1-5
RichJ53
Arrow1969 Posted at 2017-1-4 22:26
Hi Rich,
If the new metal mechanical retainer is sticking maybe this could be the root cause? Like cougar said in #18  These props could begin to ease-in over time. I would much rather have them on the tight side of the spectrum.  Keep us posted if you find our anything new.
I am very happy for your new aircraft (and hopefully I will have one too)
Rich
2017-1-5
RichJ53
Cougar1 Posted at 2017-1-5 08:47
Hi Cougar
Wow glad you got your new Inspire 2!  Did you get both of them?  You will need to tell me your impressions offline.
I will be joining you in the near future, so please get all of the bugs worked out
Rich
2017-1-5
RichJ53
Titomix Posted at 2017-1-5 06:11
Maybe like Cougar said in #18... the new prop hubs will work-in with some time.  like I said in my other post, I much rather have them tight..
Best to you and congratulations on the new Inspire 2!
Rich
2017-1-5
DJI-Jamie
Flight distance : 112405 ft
Do you have any spare props with your I2? If so, could you happen to supply a picture of the underside of them? Just to clarify, you were able to hear a 'click' when you moved the locking mechanism to the unlocked position, correct?
2017-1-5
DJI-Jamie
If you could do the same as post #22, it would be appreciated.
2017-1-5
Arrow1969
DJI-Jamie Posted at 2017-1-5 10:14
Hi Jamie,
I hope these are okay, in image 0246 the moulding mark are larger on the white docs propellers compared to the red dot ones.
Cheers Tony
2017-1-5
DJI-Jamie
Arrow1969 Posted at 2017-1-5 10:56
Hi Jamie,
Thank you for supplying these. Based on what I was able to find, there have been some units that had accidentially received prototype props. Only a few users have been affected by this, and DJI is more than happy to send out new props to you. I'm sorry that you were one of those few, I would recommend trying to take your time with lightly wiggling the prop off so as not to damage the locking mechanism. Just to make sure I'm on the same page, you are able to move the locking mechanism from locked to unlocked, but you just can't get it to come off after that?
2017-1-5
DJI-Jamie
Before trying a different set of props, can you please make sure that they look like the following underneath? You wouldn't want the same thing to happen again:
2017-1-5
Arrow1969
DJI-Jamie Posted at 2017-1-5 12:08
Hi Jamie,
No I'm not able to move the locking mechanism it is jammed it won't lock or unlock it actually stays in the locked position.
Have I still been supplied with prototype props???
Tony
2017-1-5
DJI-Jamie
Arrow1969 Posted at 2017-1-5 13:35
Thanks for that Jamie, how do I get DJI to send me some new propellers???
Again thank you very much your help
I'm confirming the best way to get that sorted as soon as possible, I'll keep you posted. Were you able to get the prop off?
2017-1-5
Arrow1969
DJI-Jamie Posted at 2017-1-5 13:43
Sorry have just edited my previous post I missed read yours.
2017-1-5
Farnk666
Titomix Posted at 2017-1-5 06:12
No, not firmware - but if you look back at the I1 launch there were issues with props.
Firstly DJI supplied prop locks free of charge.
Then when some people couldn't be bothered fitting them they changed the entire prop mounting system and supplied everyone with free replacements.
So they have some history of dealing with these issues - it's just early days.
2017-1-5
Farnk666
Donnie Stugots Posted at 2017-1-5 06:28
Cheers
I would give it at least 6 months - seriously.
2017-1-5
DJI-Jamie
Arrow1969 Posted at 2017-1-5 13:48
From what it looks like, yes you got the prototype propeller for those white arrowed ones. As far as getting the prop off, it would most likely require breaking the propeller at the hub. Since it's not the correct propeller anyway, it would not be missed.
2017-1-5
Farnk666
Oh dear....
Here's hoping that the issue is sorted out asap.
2017-1-5
DJI-Jamie
Farnk666 Posted at 2017-1-5 15:05
Oh dear....
It should be sorted out quickly. Like I said before, there are only a few packages that customers received that were affected. While it's small, I understand that it doesn't feel like much of a consolation when you end up being apart of that small percentage.
2017-1-5
RichJ53
DJI-Jamie Posted at 2017-1-5 15:16
Jamie
Thanks for getting answers so quickly on this issue. I am sure your team will fix this for the rest of the orders.
Rich
2017-1-5
Titomix
Email sent for the replacement. Waiting.
Why DJI delete the post with the info of the incorrect propellers?
2017-1-5
Cougar1
Will be interesting to see how this plays out, personally I am not convinced and think the "bad" design is actually stronger and might be a revised version. If so, no need for concern.
2017-1-5
Dragonflyin
Flight distance : 16562 ft
Sorry to read about the propellor problems.  My L2 just showed up this morning and I hesitated putting the props on...I was relieved to fly both full sets without any issue today.  i hope DJI can resolve this quickly...
2017-1-5
Dr Jon
Flight distance : 463012 ft
China
Hi Jamie,
Hate to say this but i have the opposite problems my RED props are the problem they are too small and rattle. I measure the distance between the base and the top where the clips lock and there are differences in two of the four red ones supplied.
its looks like manufacture tolerances are not accommodated by spring insert below the prop mount or in the retain clips
I contacted DJI they said its normal HaHaHa
2017-1-5
fans98d63e0a
DJI-Jamie Posted at 2017-1-5 12:10
[view_image]
I have 8 Props and they don't look like these.  Assume I need replacements.
2017-1-5
123Next >
