customize controller stick and button functions
4238 9 2015-2-14
sparksthewolf
Flight distance : 218950 ft
ok so had a thought for single controler pilots if we could customize buttons and switches using right joystickk to controle the drone forward back roll left  roll right and right stick is normal till you flip the flight mode switch to f to alow the right stick to control camera movement the c1 /c2 buttons control altitude up and down and the camera tilt rocker controles aircraft yaw enabling one pilot to get steady controle and still pilot kind of like instantly swithcing the controlrer between master and slave but still having controle over the drone
2015-2-14
alexmarnas
Flight distance : 606237 ft
That actually would be a great improvement for single operators shooting pictures...
For videos i think that a second operator is required as long as the ground station is not release for the inspire 1!
2015-2-14
dundee
Flight distance : 33550 ft
Thailand
alexmarnas Posted at 2015-2-15 14:18
For videos i t ...
You will always need 2 persons !!!
The spotter is a VIP in this
2015-2-14
dundee
Thailand
Idea is there but :
What can happen if you get confused ?
For me the C1 and camera rocker works fine if i fly alone.
Switching from tilt to pan is not the isue here, is it.
I like to keep full control with my sticks responding instantly.
Control of the Inspire1 should stay primary and camera secondary
if we talk about more safe flying
2015-2-14
jimhare
Flight distance : 239035 ft
Even if you could program the buttons on the back of the remote to pan left and right would be useful.
2015-2-14
sparksthewolf
Im saying fror more of a standpoint where you ar in the air hovering and want the inspire to act more like a tripod in the air where you than can controle the camera and make munor adjustments to its position while still controling the camera
2015-2-15
dbeck.promobox
LAME QUESTION ALERT...HOW do you calibrate the sticks with the Inspire? I know how to in the RC app for my PT2V.  It it when you launch the app on the Mini2?  Thanks!
2015-2-16
klute
Flight distance : 45278055 ft
Norway
You can easily set up C1 and C2 doing lots of stuff. I programmed my C2 to toggle between gimbal pitch and yaw so I can choose to use the left wheel to pitch og yaw, then you have full control of the camera alone. C1 I set up reset gimbal yaw, points the camera in forward position. You do this in the pilotapp under RC Control Settings. There you find C1/C2 with lots of alternatives. Works perfect.
2015-2-16
vonbaron1
Flight distance : 42014 ft
dbeck,  Look under RC settings, RC Control Settings, and RC Calibration.   Calibrate as usual following the instruction but you will also need to calibrate the camera thumb wheel on the top left as part of the calibration before you can use the "Finish" button.    Don't feel bad, I had to ask where it was also.
2015-2-16
dbeck.promobox
THanks! I knew about the C buttons but not the RC stuff
2015-2-16
