Removing OSD from HDMI
9869 20 2017-1-5
Nil73
Mexico
I am having trouble removing the OSD from the HDMI output of my P4P+.. it appears there is no menu to remove it.. Anyone else noticed this ??? It was available on the 3 and the 4,,, why not the 4 PRO+ ????
2017-1-5
Cetacean
Flight distance : 2528264 ft
Aloha Nil,
     It looks like DJI substituted the one "FullScreen" option instead of the two OSD options.  My DJI GO 4 is like that to.  Just above "About" on the General Settings page is "FullScreen", one or two finger sweep.  I chose two fingers.  If I sweep two fingers across the screen, the complete OSD disappears.  Nothing left but camera view.  When I do it again (usually from the opposite direction) the OSD reappears.  This is for both the device screen and the HDMI screen.
     I kind of like it.  It is also fast, but you have to practice the sweeps to get them consistent.  If you make a mistake doing it, you have to do it again and if you have a time issue (as in no time for mistakes), then it could be problematic.
     Hope this helps!
Aloha and Drone On!
2017-1-5
Nil73
Mexico
Cetacean Posted at 2017-1-5 20:04
Aloha Nil,
Well I found that.. but it is not a very good feature.. I would like to output the signal for an event onto the big screens.. a bit difficult to fly the drone without the osd..
Seems like DJI have dropped the ball on this one.. Give us a toggle on and off for just the HDMI please..
2017-1-6
Rjroxie
Are you saying that you can only have the camera picture on one screen at a time? That is what I seem to have and would rather be able to see the screen on mobile device as I do when I fly and also send camera view to the hdmi of my choice so that others can see it also.
2017-1-6
Grizz 1
Flight distance : 120066 ft
no, the camera view is still there on both screens, its just the flt telemetry that disappears or appears on both screens.
2017-1-6
Cetacean
Nil73 Posted at 2017-1-6 05:48
Aloha Nil,
     What Phantom are you flying?  Maybe there could be a work-around.  Oops!  Reread your original post.  You would have to use a different Phantom for the work-around.
Aloha and Drone On!
2017-1-7
Uptowndisco
Flight distance : 7394987 ft
I am in the same boat bought the Plus version for the HDMI out , but all it does is mirror the device,  unlike the older version
I had on the P3P I could choose to show only video out through the HDMI ,  disappointed !
2017-1-7
jimhare
Flight distance : 239035 ft
Uptowndisco Posted at 2017-1-7 18:54
That's really weird!  I've been considering the + for the same reason but if you can't have OSD on the remote and a clean HDMI output what's the point?
2017-1-8
Paulo Paulino
Flight distance : 2774265 ft
Portugal
I have the same problem. HDMI out without a clean output don´t make much sense.
Dji please fix this on P4P.
Thanks.
2017-1-19
fansc7a29a6c
Flight distance : 339475 ft
i've contacted dji support and they said to me that i have to wait for an update (certainly 1 month). i've bought pro +  to have hdmi output but without IOSD.
2017-1-23
multirotorrd.co
Flight distance : 6176932 ft
Dominican Republic
This way I can not do the live broadcast. I do not want that data on the screen
{:4_154:}
2017-1-24
fansa98a116e
Flight distance : 152247 ft
Denmark
Same here... It is not possible according to the DJI support guy I asked. Please fix this, DJI.
Me :
Hi Jerico.. I'm using HDMI output on my P4Pro+. I can't get rid of the OSD. I have used the "Display OSD on HDMI output" in the menu - but still get OSD on HDMI out. Latest firmware.
Even if I swipe to hide the OSD on the controller (which I'd rather not do - I just want a clean feed on HDMI out), I still get a battery percentage (and the focus selector if active). I'm about to do an event and need the clean feed
DJI :
For that you cannot dissable the OSD. on your display.
Me :
It's not supported?
DJI :
Yes it is but you will still see the OSD on your screen.
Me :
So there is no way of getting a clean HDMI feed from a Phantom 4 Pro+?
DJI :
Yes All OSD and other display will still be there.
Me :
Sorry, I don't undertand. Did you mean "no" instead of yes? As in, I cannot get a totally clean feed on HDMI out?
DJI :
Yes it is correct.
2017-5-2
Fabio Mora
Flight distance : 1730722 ft
Brazil
O Problema voltou na atualização do dia 10-06-2017
2017-6-12
Najmart-isf sky
Flight distance : 4448747 ft
Iran
Hello.
I am Mohammad from Iran.
I have your problem.
Did not give a solution DJI
I use this device to send live video and live streaming.
But why not have the OSD removal option like the previous version?
How to remove OSD from HDMI output in Phantom 4 Pro Plus?
thank you
2017-6-23
walper
Flight distance : 1477572 ft
Bosnia and Herzegovina
does anyone find solution ?
2017-7-17
fans7368db76
Flight distance : 92687 ft
GRRRR I have the same problem!!!!!!!
2017-7-24
Fabio Mora
Brazil
I think it's a shame what DJI is doing with buyers of the Phantom 4 Pro PLUS model.
The Phantom 4 Pro PLU Model is the most expensive of the Phantom line and they are not giving the necessary support.
In the last upgrade disappeared the option to enable or not the OSD, had a button in the application for this and after the last update this disappeared.
I lost some jobs because of this and DJI does not know how to correct this problem.
This screen that comes with Phantom 4 Pro PLUS SKYCRISTAL, does not allow to install other applications and not times the same update of who bought without the screen
HELPPPPPPPPPPP
2017-7-28
Najmart-isf sky
Iran
DJI
If DJI continues to do so, his popularity and capital will soon be reduced
2017-7-29
Andre Coutrim
Flight distance : 12188 ft
Brazil
Folks, it's working now.
The last update solve the issue. Just go to "HD" and unmark "Display OSD on HDMI Output". That's all.
2017-8-4
fans4c30b43b
Flight distance : 573484 ft
The new RC Pro smart controller is the same way, duplicate only. The old smart controller had the option. Can't use it this way, customers don't want to see all that garbage on the screen.
2021-12-21
Dong ZeYuan
Flight distance : 57060 ft
i have the same
2021-12-21
