I had a slight mishap, and broke a prop and the quick attach on the motor.
The DJI store sells the replacement for the P4, but not the P4P, and I read in another thread that they are not the same.
Anyone know when / how can we can get the P4P prop installation kit?
Oops , might help to try contacting one of the mods here, they maybe able to help you get parts a bit quicker, don't see them for sale yet on the web site. I suppose it's a simple thing to happen and can ground your aircraft for a couple of weeks, so maybe we all should be looking for these spares. Good Luck..
Yea it will be hard to source the newer motor prop mounts ....so for now grab 4 of the p4 motor prop mounts .....easier to source and the props will still work on them....just a suggestion to get u flying till the newer ones come in ;)
Yea reviews are because people thought they were the new ones....and one guy was mad a screwdriver didnt come with kit..really.....anyway just look around
Yes the only thing that is essentially different is the springs introduced in new p4 pro but all parts are interchangeable if u wanted to use older style p4 prop holders u could
"Patented rotor lock mechanism ensures reliable locking and tool-free mounting and release at the same time.
Fool-proof design for CW and CCW blades.
Tips: NOT compatible with Phantom 4 Pro."
Verbatim DJI site. I have the same issue and was told NOT to use the P4 mounts. The aperture of the P4P rotor spindle is larger that the P4 and shouldn't be forced on. There are folks with a method of modifying but I haven't tried it. Yet. I am going on my second month and getting impatient.
Sean Of Toronto Posted at 2017-4-11 15:20
Hi, This is a recent change. About a month ago, the P4 mounts were listed as compatible with the "P4 Series." Now I see they came out with the correct prop mounts for the P4P, and changed the wording.
I did order a set of the P4P mounts when they came out, so now my bird is happy.
