M600 1.0.0.80 Firmware Problem
1655 5 2017-1-8
P.R
Flight distance : 1135738 ft
I installed the new Firmware, and the batteries I used to make the update work fine, my other set no longer works, it seems that battery #5 has a problem, it doesn't show up in the assistant and on the go app I can only see the voltage and no other Info. The go app shows inconsistent firmware, but why won't the battery show up in the assistant?
When I turn on the m600 only 2 batteries lights work, the other ones seem to be turned off, I can see them on the app and assistant tough.
Downgrading and upgrading didn't work, they don't even work with the older firmware anymore, when downgrading and upgrading with the 2nd pack I get a error in the assistant that the battery is not connected.And the M600 is beeping when it's turned on with those batteries.
The #5 battery seems to work fine when charging and discharging with the smart powercharge.
Any solution?
2017-1-8
P.R
Is there a way to reset the Battery?
2017-1-9
shawn_
Flight distance : 256791 ft
This is pretty basic, but are all the batteries topped up? If one has self discharged and there is more than 10% voltage variation, it acts similar to what you're describing. I'm sure you checked that, but wanted to toss it out there.
2017-1-10
P.R
shawn_ Posted at 2017-1-10 07:14
Yes they were, I suspected that to but wasnt that, I did try a new down and update and they seem to work now, let's see how it works these days
2017-1-10
shawn_
P.R Posted at 2017-1-10 07:27
Good deal, keep us posted.
A lack of support for these expensive aircraft sure adds frustration to it all. Only real resources is the other users on here.
2017-1-10
DJI-Jamie
Flight distance : 112405 ft
Good to hear you were able to get that sorted.
2017-1-11
