Connecting and Linking the N3 with the Futaba S.BUS Receiver
864 6 2017-1-10 21:10:51
China
Here's how to link the N3 flight controller with a Futuba S.BUS Receiver.
2017-1-10 21:10:51
CFROY
Beginner
Hello Mindy, I'm looking for a S1000+ setup without camera and want to confirm it without buying:
2017-1-16 12:17:13
CFROY
Beginner
Hello, i'm looking to run a DJI S1000+ with a custom payload with the new DJI GS PRO app.
will this setup work or am I missing something ?
- DJI S1000+
- N3 flight controller
- Datalink Pro
- Any SBUS receiver (like FUTABA)
Thank you for your response!
2017-1-16 12:20:57
CFROY Posted at 2017-1-16 12:20
Hello CFROY,  you need to use LB2 instead of FUTABA.
As for datalink Pro, it's not necessary.
2017-1-17 03:32:56
CFROY
Beginner
Thank you for your response, so I will buy:
- DJI S1000+
- Lightbridge 2
2017-2-15 08:04:46
memo.problem
Hobbyist
Russian Federation
if you buy this set  - you cant retract gear - because DJI do not whant repair F-port on N3
2017-3-2 21:46:59
Inconceivable 7
Hobbyist
Pakistan
Hello CFROY, you will also need f channel expansion kit if your custom payload needs to be controlled through lb2 (pan and tilt)
2017-3-14 05:20:22
Close
DJI RecommendsPrevious /1 Next
