Loose prop mounts
1771 11 2017-1-11
Viridis
Flight distance : 2383556 ft
Looked for the previous topic where prop mounts had a little movement in them.
Was it considered normal in the end?
2017-1-11
hallmark007
Flight distance : 9827923 ft
No you need to tighten them, obviously an oversight...
2017-1-11
ePetLicensing.c
hallmark007 Posted at 2017-1-11 10:00
What I noticed is some are tighter than the others but NOT for a lot. Also make sure your volume on the display is loud so you can hear the beeping warning if one of the props is loose.
2017-1-11
Viridis
Thanks, I did think it was a bit odd that 3 move slightly
2017-1-11
Viridis
They pretty stiff even though mount is loose?
Odd
2017-1-11
ePetLicensing.c
Viridis Posted at 2017-1-11 10:21
I think they are meant to be this way, because I checked all my drones, P3P,P4,P4P,P4P+ and all have the same issue. I think some flies at different speed to compensate!!!
But you need to check before every flight that they are tight and if by any chance you missed one, the display will be beep very strong and loud beep AND YOU NEED to bring the drone down and verify all the props. It happened to me once. I rushed out of the card set up quickly and flew and I kept hearing the LOUD BEEP.
So now, I always make sure to hover for at least a miunt or two waiting and there is NO BEEP OR WARNING then I will FLY.
2017-1-11
Viridis
Thanks again.
Will be vigilant with this.
2017-1-11
Snowwolfwarrior
Flight distance : 1064780 ft
They may use a bit of thread lock, that's why the screws feel tight but mount is loose, probably best to remove each one in turn and add a little medium thread lock fluid and tighten beck in, you can either do that or send it back to DJI
2017-1-11
DJI Natalia
Flight distance : 318 ft
Viridis, we're aware of that, will improve the product quality control.
While it does not have negative influence on aircraft's performance, please do not worry about it.
2017-1-12
Andy LIS
Flight distance : 3358875 ft
I found on my P4Pro, three of the four prop adapters were a little loose.  The mounting screws were bottomed out (they are shoulder screws) and torqued up correctly, so no amount of tightening them further would have helped.  I ended up making some packing shims from tape to remove the clearance.
Andy
2017-1-12
Viridis
I wonder if it's because the actual clips look identical to p4 except... They don't have the metal push plate underneath them packing them out?
2017-1-12
Nigel_
Flight distance : 388642 ft
"But you need to check before every flight that they are tight "
Draw a thin line across the top of the mount screws with a permanent marker, then when you fit the props it only takes 1 second to check that the mount screws haven't turned so aren't coming loose.
Doing this will remove the temptation to over tighten the mount screws to ensure they don't come loose, over tightening is not good with such small but critical screws.
2017-1-12
