Battery Issue with Ronin-M
998 0 2017-1-13
Tallman
Hello all,
Hoping that someone else here has solved this strange issue.
Purchased my Ronin and its batteries all from DJI directly.
After a few hours using the Ronin when I change to another fully charged battery, sometimes the Ronin will not work.  I replace the battery, start up the Ronin and after a few seconds of startup the Ronin's stabilizer system shuts down and the camera platform goes loose.
On one shoot out of the 5 batteries I have only the one battery, the one I started the day with, would run the Ronin.
On another shoot I had the same problem, so I shut off the Ronin, pulled the battery off and swithced to a slider to shoot for about 20 minutes.  When I returned to the Ronin and put in another fully charged battery it suddenly started working again.  Testing I went through the other batteries to see if they all now worked and they did.
Does anyone have any idea why this is happening?  There is no consistency on which batteries work and don't so i think the issue is with the Ronin.
Please help with any suggestions you can!
Thanks
2017-1-13
