DroneFlying
Flight distance : 10774613 ft
Eagle_Eye Posted at 2017-5-10 11:48
Since we are in the topic of HP..
If I started my flight and set HP to AC, then in mid flight I decided to change this to RC (if possible via SW).
If I engaged RTH, theoretically it will come home to where the RC is @....right?
It's possible if your mobile device has GPS; otherwise you can't. For example, the cellular version of the iPad Mini does include GPS but the wifi-only version doesn't, so you can't change the home point to the remote's location with the wifi version.
Yes. It will return to wherever the home point is set to, so if you updated it to be the remote's location then it would return to that location.
What if the RC disconnect, will it RTH to 1st HP?
Not if you changed it; it only keeps track of a single home point and in the case of a disconnection will return to that location. |
