Zenmuse Z15-5D III (HD) Problems with image transmission
886 1 2017-1-19
vonganzoben.de
Flight distance : 930161 ft
Hi!
I´m a little in trouble with me Zenmuse Z15-5D III (HD). I use it with a Canon EOS 5D Mark III and a Canon EOS 5DsR (both latest firmware) without problems most of the time.
But sometimes, when i power up the drone i don´t get a video feed. I got also an issue when releasing the shutter and taking a picture that the screen went black (what is obviously normal) but stays black. When i take a second shot the video feed will be stable again and so on.
But the main problem is, that i sometimes get no connection when powering the drone up.
Any hints?
Both problems are present since i own the Gimbal. Flown in different setups (Old: S1000+, A2, LB1, New: S1000+, A3 Pro, LB2) but the problem stays the same, so it must the Zenmuse-related.
2017-1-19
vonganzoben.de
EDIT: All LEDs are solid green and in DJI GO the output is always set to EXT with 100% ;)
2017-1-19
