Anti-collision lights
12Next >
17561 64 2017-1-20
uaservices
Flight distance : 262785 ft
I was wondering if anyone knew of anti-collision lights that would work on the P4P and meet FAA requirements.
2017-1-20
Maxi3D
Flight distance : 307621 ft
You can try Lume cubes with red and green filters.
2017-1-20
hallmark007
Flight distance : 9827923 ft
https://www.lumecube.com/shop/lume-cube-phantom-4-kit have a look at these, not to sure if they meet FAA requirements..
2017-1-20
Nigel_
Flight distance : 388642 ft
These claim that they do: http://www.flytron.com/led-syste ... e.html#/color-white
Not the smartest of lights, but they are so small you don't really notice and they work very nicely, also having mounted them on the Phantom with 3M sticky pads, it still fits in the standard case so they can just stay attached.
2017-1-20
RedHotPoker
Flight distance : 165105 ft
I can vouch for Lume Cubes and would highly recommend them to anyone wishing to increase their drone VLOS. &  as well, improve upon your drone photography limitations
http://www.lumecube.com/164.html
Check out the galleries. . . ;-)
RedHotPoker
2017-1-20
Darrendirl
Flight distance : 822021 ft
Are the built in lights not enough for the faa?
2017-1-20
RedHotPoker
The problem with oncoming air trafic is they aren't going to see your drones stock LED's as they point primarily downward. And are not very bright.
They work great for us, particularly at night, as we are below them.
By adding some brighter, more directional LED lights, you can be seen from a much greater distance, by larger incoming or nearby aircraft.
RedHotPoker
2017-1-20
uaservices
Nigel_ Posted at 2017-1-20 10:00
These claim that they do: http://www.flytron.com/led-systems/319-strobon-standalone.html#/color-white
Would be able to share a picture of how you have it or them mounted on your aircraft?
2017-1-20
RedHotPoker
uaservices Posted at 2017-1-20 17:53
Probably some Velcro or 3M double sided foam tape.
The Lume Cubes have 3D printed mounts and the LED's are adjustable for direction. ;-)
RedHotPoker
2017-1-20
DJI-Jamie
Flight distance : 112405 ft
Darrendirl Posted at 2017-1-20 14:53
RedHotPoker hit the nail in the head in post #7. The stock LEDs are primarily for the user to get better orientation from below.
2017-1-20
Nigel_
If you really want your aircraft visible to other aircraft then I think you want one on each side mounted as below and with the correct  colours for the sides.  They are fairly wide angle, about 120 degrees, but unlike a proper aircraft strobe you don't see much if looking fully side on.  I think they are 3W LEDs, but since they are off most of the time so don't get hot, they are being run in excess of 3W so they are really quite bright.  I ran a test when new and got 7 hours runtime, quite amazing for the tiny battery!
Note that I have it attached where it is pointing slightly downward since I use it to make the aircraft visible to me at long distance.  Helps a lot on cloudy days when the aircraft is against a dark background such as trees.
Even with 4 attached, you wouldn't notice the extra weight, carrying the weight of 4 Lume Cubes might not be practical!
2017-1-21
rodger
Flight distance : 20145135 ft
The FAA requirement is 3 miles and only during Civil Twilight. They also may be dimmed if they are going to cause a problem with other Aircraft.
2017-1-21
Grizz 1
Flight distance : 120066 ft
I use the flytron and the lume cubes, makes it a lot easier to fly LOS
2017-1-21
Nigel_
Grizz 1 Posted at 2017-1-21 10:37
How much more visible are the Lume Cubes than the Flytron strobe?
I'm guessing there is not much difference in light output but the Lume Cube is more directional so the light is more concentrated?
2017-1-21
Grizz 1
the lume cubes are larger and put out much more light
2017-1-21
bobo
Flight distance : 1544416 ft
DS-30 LED White Drone Strobe UAV Strobe Locator.https://www.amazon.com/gp/produc ... 1_s00?ie=UTF8&psc=1 I am installing it on my Inspire Pro. It excedes the FAA requirment for 3 mile. If it works out ill be putting it on my M600 and Inspire2
2017-1-21
Grizz 1
bobo Posted at 2017-1-21 16:34
I've got a few of those also, but mounting on a P4 is not easy, I have some saddle bags coming for the battery holder.
2017-1-22
RonBurk
Flight distance : 4844216 ft
A quick look at the Lume Cubes flying -
2017-1-22
fans9a7c0aa0
Flight distance : 8327 ft
I just ordered one of these:  http://www.firehousetechnology.c ... _Q500_RC_Plane.html
2017-4-27
fans9a7c0aa0
NO They won'T
2017-4-27
fans9a7c0aa0
No not by a long shot!! They point down. An aircraft above the drone probably would not see them andd they are not bright enough. Try Lube Cubes or for a much cheaper option try this:
2017-4-27
OscarD
RedHotPoker Posted at 2017-1-20 11:04
I'm assuming these work on the P4P too?
2017-4-27
RedHotPoker
OscarD Posted at 2017-4-27 19:32
Yes, Lume Cubes have already designed mounts for the Phantom 4.
They even created mounts for the Phantom 3 Standard too.
The Mavic mounts are in the process,  & are being released very soon.
RedHotPoker
2017-4-27
tkflyfisher7
Flight distance : 150164 ft
LUME CUBE!
2017-4-27
RedHotPoker
Maxi3D Posted at 2017-1-20 06:20
Those colored filters are coming very soon. As of now they are still in a preorder stage.
RedHotPoker
2017-7-1
RedHotPoker
Nigel_ Posted at 2017-1-21 03:44
Why would anyone wish to attatch 4 Lume Cubes to their drone? I don't see the advantage...
RedHotPoker
2017-7-1
fansfe6a9925
Flight distance : 13625 ft
Wrong answer. Re-read the question. The member was asking about anti-collision lights, not headlights.
2018-1-15
fansfe6a9925
hallmark007 Posted at 2017-1-20 06:53
Wrong answer. Re-read the question. The question was about anti-collision lights, not headlights. You're suckering readers into an FAR violation situation.
2018-1-15
hallmark007
fansfe6a9925 Posted at 2018-1-15 16:34
What is your problem, this was back last July how many people have died because of what I said, and has the sky fallen in.
2018-1-15
RedHotPoker
RedHotPoker Posted at 2017-7-1 00:19
I got my Red & Blue gel filtered colors for my drone several months ago, and really like them, a lot.
They look awesome, blinking back and forth. ;-)
RedHotPoker
2018-1-15
RedHotPoker
fansfe6a9925 Posted at 2018-1-15 16:30
Putting the Lume Cube in one of seven Stobe modes they become much more than headlights.
They cast light at a wide beam, not directed strictly straight ahead light stream.
Colored filters can now also be added magnetically, by using a Lighthouse.
RedHotPoker
2018-1-17
RedHotPoker
Would you prefer using the Red & Green filters, over Red & Blue?
RedHotPoker
2018-1-17
fansfe6a9925
hallmark007 Posted at 2018-1-15 16:47
1) Again, re-read the answer to discover what my problem is.... which is figuring out what YOUR problem is.
2) The FARs concerning anti-collision lights have not changed since July. So don't blame your problem on July.
3)  How many people have been killed?  There has been at least a couple of midair collisions of Phantom drones and full-size aircraft, because the pilots couldn't see the drones, hence the anti-collision lights and FAR requirements.
4) My problem? Stupid people giving advice on public forums.
2018-1-19
PeteHB
Late to the debate but Lume Cubes with proprietary P4 mounts in strobe mode do it for me.
2018-1-19
RedHotPoker
PeteHB Posted at 2018-1-19 12:01
Have you tried the Lighthouses with colored filters?
I love to have mine blinking Red And Blue. Hahaha
RedHotPoker
2018-1-19
PeteHB
RedHotPoker Posted at 2018-1-19 13:44
Can't get any at the moment.
2018-1-19
RedHotPoker
PeteHB Posted at 2018-1-19 14:12
All peripherals are rather pricey. Much like the entry fee, with cubes and appropriate mounts.
RedHotPoker
2018-1-19
hallmark007
fansfe6a9925 Posted at 2018-1-19 11:54
Hey troll , No people killed, No people injured, midair collisions No damage done also in both cases drones were not using Lume Cubes if the were collision could have been avoided.
Seems like the most stupidest person on this forum has arrived way to late.
“People think it must be fun to be a super genius, but they don't realize how hard it is to put up with all the idiots in the world.”
2018-1-19
PeteHB
RedHotPoker Posted at 2018-1-19 14:14
Problem is I can get the gels but not the Lighthouse cage.
2018-1-20
lannes
Flight distance : 4465 ft
PeteHB Posted at 2018-1-20 01:09
Look like you need to buy them from Australia
https://www.ebay.fr/sch/i.html?_nkw=322527078014
2018-1-20
12Next >
