phantom 4 pro fans too noisey
2944 21 2017-1-25
fans18094883
Flight distance : 70108 ft
new phantom out of the box (up dated firmware) very noisey concidering exchange or ?...
normal or ...?
2017-1-25
Jkeller84
Flight distance : 396955 ft
That's normal.
2017-1-25
hallmark007
Flight distance : 9827923 ft
Will sound a lot noisier indoors, when it's 250 ft in the air you can hardly hear it. Good luck..
2017-1-25
fans18094883
many posting show a silent or quite phantom very low noise in idle . how can i be sure its not a defect?
2017-1-25
usere1c0332ac8
Normal!! Sounds just like mine.
2017-1-25
usere1c0332ac8
Sounds like mine. Normal
2017-1-25
fans18094883
other postings recommend replacement had solved noise problem..
2017-1-25
Jkeller84
fans18094883 Posted at 2017-1-25 12:05
Go ahead, try your hand at DJI service if you are so inclined. I can tell you, that I have a P4 and P4P and both of them sound similar. No issues, many many successful flights.
2017-1-25
Maxi3D
Flight distance : 307621 ft
Mine sounds that way too.
2017-1-25
Svt04cobra
That is normal for when you start it up. Mine is exaclty the same and is brand new also.
2017-1-25
Labroides
Flight distance : 9991457 ft
Your Phantom has an internal fan to prevent overheating.
That's what you can hear.
2017-1-25
fans18094883
mayb im paranoid, exchanged for another ...same sound?.....
2017-1-25
Jkeller84
fans18094883 Posted at 2017-1-25 15:10
Why did you even bother to ask for help if you were going to exchange it anyway?
2017-1-25
hallmark007
I bet you drive a Prius. Lol
2017-1-25
browncoat
Flight distance : 12497 ft
2017-1-25
theGrindLab.com
Flight distance : 1375846 ft
Sure, there may be units that are quieter, but that does not mean yours if faulty. That noise level is nothing to be concerned about.
2017-1-25
fans18094883
hallmark007 Posted at 2017-1-25 16:19
oh nooo there waay weird engine starts and stops them weird to me!!
2017-1-26
Shockwave
Flight distance : 27274 ft
I've had 2 and both sound exactly the same... normal
2017-1-26
Hendo
Flight distance : 104495 ft
New Zealand
2017-1-26
DJI-Jamie
Flight distance : 112405 ft
The fan can kick in sooner depending on the temperature of the room and whether or not you've been playing with it prior and did not let it cool down. The noise level of the fan is normal. If the sound is louder, has a higher pitch, or is not consistent (clicking etc.), then the fan may have an issue.
So far, that video indicates that the fan is working normally. If your replacement has the same sound, then you're fine.
2017-1-27
fans18094883
Shockwave Posted at 2017-1-26 12:59
ok . i did get a replacement sounds the same..
2017-1-27
droidman2177
Flight distance : 20820 ft
Lol (shakes head)
2017-1-29
