Video timestamp issues with Lightroom
1768 17 2017-1-27
Jeff Goldberg
Flight distance : 1457329 ft
This may be a dumb question, but it's really odd.  I pop the microsd out the Mavic and import into Lightroom.  The images import fine like the 100s of thousands of other imports.  However, for videos, Lightroom doesn't see the timestamp info properly.  Anyone else have this issue?  For now, I import the images, copy the videos and then import in "add" mode to put them into my catalog.  Thoughts?
Jeff
2017-1-27
fans97dafa65
New Zealand
I also have this issue--the month and date are correct, but for videos the year comes up as 1951. I can manually change it, of course, but that seems like a simple thing to fix (perhaps in an update).
2017-1-27
Hummingbird.UAV
Flight distance : 27489951 ft
I don't see the date in my video meta data in Lightroom.
Lightroom isn't really made for video but it does let you quickly review whats in a clip by just running the curser over the thumbnail.  If you could highlight a sequence of clips and then right click them and transfer them to a Premiere timeline it would be a great tool.  I usually file video by subject, each subject gets a unique folder named after the subject.  I then add this folder to the Lightroom catalog.
2017-1-27
braddahjosh808
Flight distance : 1868376 ft
I'm having the same issue with my Phantom 4 Pro. The created date on my videos show as year 1951. I don't have this issue when using the Mavic.
2017-1-29
Jeff Goldberg
braddahjosh808 Posted at 2017-1-29 18:09
I connected the mavic directly today and had the same problem with the year.  Very odd.  The file info is correct, but somehow the metadata in the file is off which is what Lightroom is reading.
2017-1-29
braddahjosh808
Anyone found a solution to this?
2017-2-9
RearViewMirror
braddahjosh808 Posted at 2017-2-9 13:21
Don't use LR for video?
All kidding aside, the only thing I use LR for is developing RAW photos. I do use it for color correcting (developing) RAW images for timelapse video but I import the string of images into Final Cut Pro or Adobe Premiere Pro for the finished video.
2017-2-9
braddahjosh808
RearViewMirror Posted at 2017-2-9 13:55
What software do you use for importing videos? I like Lightroom because It automatically imports media into folders based on date taken.
2017-2-10
RearViewMirror
braddahjosh808 Posted at 2017-2-10 13:20
I process all video with Final Cut Pro X or Adobe Premiere Pro CC.  I use Lightroom almost exclusively for developing photos with the exception of developing a batch of photos for timelapse movies. But even then I render them with either Final Cut or Adobe Premiere (Adobe has a better warp stabilizer for hyperlapse).
2017-2-10
FBNBLZR
Flight distance : 19570 ft
hey guys, i am having the same issue, there still seems to be no workaround, right?
cause its really annoying that u have to switch to another year-folder
i use LR to import everything cause it makes things so much easier with importing footage and it makes everything easier when u work with the footage then, when u have everything in the corresponding folder
for example: today is feb 11th 2017, but the footage (not the images!) were put in the folder for feb 11th 1951
2017-2-11
Jeff Goldberg
FBNBLZR Posted at 2017-2-11 09:13
Still broken for me
2017-2-28
ClancyO
Flight distance : 296053 ft
Oh man, I haven't run into this issue yet.  I definitely rely on LR for importing and file management from all my photo and video sources.
2017-2-28
Jeff Goldberg
ClancyO Posted at 2017-2-28 14:48
What version of Lightroom at you using?  I would love to see this go away.  I don't have the issue on photos, but still there on videos.  I am using LR CC 2015.9 (which I believe is the latest release).
2017-3-12
kikap
Flight distance : 18012 ft
See my reply here: https://forum.dji.com/thread-84525-1-1.html
We need to attract the attention of DJI team, it is a very simple fix for them.
2017-3-12
ClancyO
Jeff Goldberg Posted at 2017-3-12 12:34
I'm using the same version, CC 2015.9.  It would have to be something with the clock on the Mavic and what it's writing to the metadata.
2017-3-14
fansc11f497b
I spent about 40 minutes on support chat a couple of days ago because my videos all have a timestamp of 1951.  The agent's response was "that's weird."  After sending several screenshots, he said he would have to look into it and get back to me.  I haven't heard from him.
2017-3-15
kikap
I came up with an ugly solution, works for me while DJI is (or not) fixing the firmware.
https://medium.com/@kikap/dji-ma ... cfd97148#.efcsou5n9
2017-3-15
Jeff Goldberg
kikap Posted at 2017-3-15 23:49
https://medium.com/@kikap/dji-mavic-pro-video-files-wrong-date-5482cfd97148#.efcsou5n9
Thank you for the workflow option.  At the moment, I just import the photos then manually copy and import the videos in place.  Seems like an easy firmware fix.  Don't know why it's still not fixed.
2017-3-16
