Firmware Update failed at 65% (0x020103 error code)
4482 24 2017-1-30
GHOZT
Hey guys,
I have an serious problem with my new Phantom 4 Pro. It comes with the Firmware V01.01.0201 and told me to update to the actual firmware V01.02.0304. After I´ve tried it by the app and it didnt work I´ve tried it with the DJI assistant 2. It shows me the Firmware there but every time I try to upgrade its get stuck at 65% and the Phantom restarts. After this it shows the "update failed" Screen and the Error Code 0x020103.
I´ve tried to refresh the actual firmware and try to update again but it didnt work. Could anybody please help me out? I´ve seen some posts with the same problem in the forum. The guys received a file and some Intructions and the firmware update worked after this.
Could you please send me this files and Informations too? My Email is i.gerencser@gmx.net
Thank you!
2017-1-30
Dmitryb67
Flight distance : 791194 ft
Russia
Hi there, I have exactly the same problem! The first firmware update (received the drone on Jan 27) after unpacking, connection and turning on went well. Then, after 2 days of little flying I received a warning in DJI Go 4 App "Camera error (code 01)". After that, appeared the message on the initial page of Go 4 "Incompatibility issues may occur between some modules and the device.
2017-1-30
Dmitryb67
Russia
Continue update?" After clicked "Yes", update status bar went fast to 20%, the drone rebooted and update failed at 73% with the message "Update failed!" Pls let me know when you receive help on this issue. My email db-2003@yandex.ru Thanks. Dmitry
2017-1-30
dronist
Are you using IOS or Android? My experience with IOS you need to use IPHON6S+ or MINI4 with fast internet connection. I updated mine several times with no issues.
Also make usre you cforce close any apps except the GO4 app, good luck!
2017-1-30
GHOZT
dronist Posted at 2017-1-30 19:18
Yeah I´ve used my Ipad Air 2. And any other App was closed. But it doesnt work with the DJI Assistant 2 App too. My Internet Connection is fast as hell. I will give it a try with my iPhone 6s Plus at the evening. Thank you!
2017-1-30
Dmitryb67
Russia
Thanks for the guidance, Dronist. Haven't tried it with iPhone6s (don't have it), but tried with Assistant 2. Result is the same - Update failed. However, it can be successfully downgraded to v01.01.0203, but doesn't help in my case, because on top of FW upgrade issue I also have CAMERA ERROR warning in GO 4 app that came out of nowhere.
2017-1-31
SPIKE_151
Flight distance : 69767 ft
DJI Mindy will send you a link to download the update file. Format your sd card, upload the file to the sd card , and switch the drone on, DJI Mindy can you provide a dowload link for Dmitry to download the update file please.
2017-1-31
GHOZT
SPIKE_151 Posted at 2017-1-31 04:53
Yeah this sounds like the update with a Bin file like the older models. I need exactly this file but nobody want to send it to me. It would be awesome to get it. DJI Mindy.
THX Spike! Maybe this helps.
2017-1-31
Dmitryb67
Russia
Spike, thanks a lot! This sounds like a real help! My email address is db-2003@yandex.ru
2017-1-31
Dmitryb67
Russia
DJI Mindy, me email address to send the update file is db-2003@yandex.ru. Many thanks in advance!
2017-1-31
SPIKE_151
Dmitry the update file is over 80 megabytes in size, when Mindy gets back from chinese new year holiday im sure she will put the file in a dropbox , and you can download it from there. DJi has dedicated bandwidth for the drop box. Most of the these download update problems are due to issues of slow downloads. The drop box bandwidth will help in getting the download faster
2017-2-1
Dmitryb67
Russia
SPIKE_151 Posted at 2017-2-1 00:12
Spike, Got it! Thanks for clarifying. Do you know if this "magic" update file has helped other fellows on the same problem? I'm also wondering what triggered this problem in my case? When I initialized the drone, I had no issues with FW update. But then, Camera Error popped up followed by Update failed issue.
2017-2-1
SPIKE_151
Yes it certainly has helped many others , I will look for the original thread and post it up here
2017-2-1
Dmitryb67
Russia
SPIKE_151 Posted at 2017-2-1 01:57
Thanks, Spike! Will wait for your post
2017-2-1
Grizz 1
Flight distance : 120066 ft
make sure the aircraft battery is more than 50%, preferably 100% charge, then retry. hope this fixes this prob.
2017-2-1
GHOZT
I didnt hear anything from DJI Mindy. I had three batteries to upgrade the aircraft and all of them had 100% so thats not the problem in my case.
2017-2-3
DJI-Jamie
Flight distance : 112405 ft
GHOZT Posted at 2017-1-31 05:59
Sorry to hear you're having issues, I sent you a PM with the info.
2017-2-3
DJI-Jamie
Dmitryb67 Posted at 2017-1-30 01:34
Continue update?" After clicked "Yes", update status bar went fast to 20%, the drone rebooted and update failed at 73% with the message "Update failed!" Pls let me know when you receive help on this issue. My email  Thanks. Dmitry
I sent you a PM as well.
2017-2-3
Dmitry495
Russia
DJI-Jamie Posted at 2017-2-3 14:25
Jamie, Thank you very much! I really appreciate your help! I will try and let you know the outcome
2017-2-3
DJI-Jamie
Dmitry495 Posted at 2017-2-3 22:55
Please keep me posted.
2017-2-4
Sobey1
Flight distance : 15200 ft
Hi I seem to be having the same problems with my phantom 4 pro as these guys with same fails and same error codes, but luckily.the company I got it from have agreed an exchange. Could I get a link to the download though just in case I get it with the new one.
email is: martynsobey@gmail.com
2017-4-20
josjr
Flight distance : 409268 ft
Brazil
Can you help me?
my email is
josjr-@hotmail.com
2017-11-9
BraveSpirit
Flight distance : 205007 ft
I probably need help too with this Firmware Update. I would appreciate it in advance. Hernan.Espiritu@outlook.com
2017-11-9
pjkjBF5sjFj8
Flight distance : 4708 ft
Hey,
To help anyone who experiences the same issue here as I also received the error - Update Failed. REASON: 0x0201003
The bad news is there is no solution.  I've tried everything and speaking with DJI support, the only solution is to send it in for repair.
I'm really annoyed with DJI for this because there is no issue with my drone as such.  I was flying it just fine without updating the firmware until they FORCED the latest firmware update.  They effectively "bricked" my drone.  It worked fine without the firmware update, because I couldn't update it ever.  I've tried over 10 months with the latest updates in the hope one would work.  Until they basically did a forceful push of a update through the android app that said the drone had a warning and stated it was unable to fly on the app.  But I couldn't update it?  And I couldn't fly it.
Annoyingly I bought it in the USA and live in the UK.  Warranties are regional only so I have to post it to the USA service centre and receive it locally also.  Frustrating they won't send it to the UK!  So a lot of faffing with virtual addresses and expensive shipping costs.  For helpful reference you can setup a virtual address in the USA fairly easily and use this for receiving and forwarding on wherever you live.  I used Shipito for those interested.
Luckily it was just 1 month within the 12 month warranty period.  I would have been super angry if it was outside as they would have charged for the repair.  DJI - you should not be able to brick a product like this as you did it automatically through an over the air update to my app.  I did not choose this.  For anyone else who has experienced the same issue, you should voice your concern here.  I'm sure there are many who fall outside the warranty period and have worse situations than me.
As an update - I have only just posted it to DJI in the USA.  I will update once I receive back in working order.  It's got to travel about 10,000 miles - so maybe it will have the record for miles flown!!
John
2018-4-15
Vendex
Flight distance : 16722920 ft
Bulgaria
pjkjBF5sjFj8 Posted at 2018-4-15 13:15
Hey,
Hey, just open a case and send the drone to the nearest location, this is the best solution. Let them fix it
2018-4-15
