WA5TEF
Flight distance : 124672 ft
Yeah, I have thest posts on several different places and it is difficult for me to recall where all I posted. Here is the summary again, I flew into a tree on 11/24 and it chopped its way down through the tree at idle power. I lost three props I think, and some scratches but no other damage. Then, I flew it many times with DJI GO and Litchi with no problems. On January 21, I flew it to 417 feet, took a still shot ()I had to turn off the video recorder to do this but failed to turn it back on since I was only making this one photo) and then started a descent. In fact it crashed in almost the same spot it took off from. And no I did not lose a prop since all four were still attached and I have photo evidence of this since I video'ed the site plus made still shots of it. Had I lost a prop, the craft would have turned probably in a spiral instead of a perfect flip. It was horizontal and stable while falling and I did not realize it was inverted so I applied full throttle to stop the fall. But, since it was upside down, it increased the fall and hit the ground hard and bounced. When I got to it, the lights were still on, the battery was on with three green LED's lit and the fourth one blinking. As I have said, it took quite am impact and survived. DJI should be proud of their construction!
Thanks for following. I'll post the results of the flight data logs when I get them.
Thanks,
Jim
WA5TEF |
