hallmark007
Flight distance : 9827923 ft
When you set out flying, it is your responsibility to plan your flight, where your flying , how much battery you need to fly your mission, assess the risks , and fly with your safety and others in mind , simply if you were going to try fly the Mavic to its limit, you should have thought about what happens if something goes wrong, can I find a safe place to land for one.
You where trying to fly an 8k round trip, what is the speed of the wind if let's say it 10mph and you have to come back up wind in normal mode, then the fastest speed I will have coming home is about 12mph how long will it take to do the trip, these are simple things to work out, and they are very much your responsibility.
Another thing flying 4K you absolutely don't have VLOS which is a requirement flying SUA , you choose to ignore this.
But you can put many at risk, i.e. Small aircraft, helicopters, hand gliders, if you read the manual as you said cover to cover, you would have come across this.
If you are not sure what exactly what's going to happen with your aircraft on such a long trip then you shouldn't take the risk,
I know this is probably an expensive lesson for you to learn, and I'm sorry you lost your AC , but I'm afraid this is an open and shut case of pilot error.
Thank you for posting others may learn from your mistakes.
Good luck.. |
