M600 ADDING ANOTHER GPS- HELP!
1277 2 2017-2-4
bobo
Flight distance : 1544416 ft
GPS Help!
I have the original setup for the single GPS unit install, and am adding an additional GPS. I connected everything and the IMU and Compass all light up when turned on. I can't get the Assistant2 to see the other GPS. Any suggestions? FIRST pic is how I want to hook it up. ( not my pic, from another owner) 2ND Pic Nothing but the one GPS column highlights as pick one with the second GPS plugged in.
2017-2-4
bobo
All that are interested, I found out the problem. The GPS unit I purchased needed to have the same firmware as the bird. once I did a upgrade thought assistant2 it found the GPS/IMU and was able to to  my positions. After that I did a compass Calibration and all is good! If this was mentioned in the GPS upgrade manual in bold it would save a lot of guess work.
2017-2-4
DJI-Jamie
Flight distance : 112405 ft
bobo Posted at 2017-2-4 09:45
Good to hear that you were able to sort it out.
2017-2-4
