New DJI GO update - problem with Osmo Pro X5
1451 9 2017-2-6
Rovuille
I HAVE UPDATED MY APP DJI GO FOR OSMO PRO X5., AND THE PEAK FOCUS THRESHOLD DOES NOT WORK ANYMORE, NOTE, I USE WITH OSMO PRO X5 THE FOLlOW FOCUS HANDWHEEL MOD. FH01 AND
WITHOUT THE PEAK FOCUS IT'S IMPOSSIBLE WORK FOR ME. BEFORE THIS UPDATE  EVERYTHING WORKED. CAN YOU HELP ME PLEASE
2017-2-6
fansd024f813
Flight distance : 2104931 ft
Same issue here, have not tested to see if it works with X5 on the Inspire. Suggest you use a backup and reinstall the last  version of the go App. I'm using IOS by the way.
2017-2-6
kecav
Flight distance : 10641243 ft
Czechia
fansd024f813 Posted at 2017-2-6 15:32
I have the same problem. After reinstalling the app is a problem same.
2017-2-7
fans9df04ad8
Flight distance : 1052612 ft
Same Problem here.
IOS 10.2.1 - iPhone 6splus . DJI GO App 3.1.4
DJI OSMO RAW
2017-2-7
kecav
Czechia
This is a big problem that does not allow to correctly use OSMO. Work is underway to correct the problem?
2017-2-8
fans33d66fc2
Flight distance : 45771 ft
Mine is working. IOS 10.2.1 - iPhone 7plus - DJI GO App 3.1.4
2017-2-8
fans33d66fc2
fans33d66fc2 Posted at 2017-2-8 17:57
Should have also mentioned that I'm using Osmo Pro and that the update turned my focus peaking off.  After turning it back on in the settings, all is good.
2017-2-8
kecav
Czechia
fans33d66fc2 Posted at 2017-2-8 18:04
The problem may be that I'm using Osmo raw. " fans9df04ad8 ´ also uses raw Osmo.
2017-2-9
Tima_007
Flight distance : 1110312 ft
Ukraine
Yes, same issue on my OSMO PRO. After update DJI GO on my Apple iPad Air 2, focus peaking in not work! The option is have, but cant set eni procentage value.
Dear DJI, please fix this bug fast becouse yor device without focus peaking is  li using GOPRO
2017-2-12
DJI-Thor
Flight distance : 13602 ft
Hi,please connect your phone to Internet and the DJI Go app also needs acces to Internet. Then it will update the app.  The new app should have this option available again.
2017-2-12
