N3 X3 not receive data
2200 21 2017-2-8
timkkkk
Flight distance : 122162 ft
Belgium
I have installed x3 on quadcopter with N3 and LB2 with X3 gimbal adapter for matrice 600
i have latest updates + updated camera x3 for matrice 600 => is this correct firmware?
DJI go app says "gimbal cannot receive main controller data"
2017-2-8
Robin UAV
I had a similar problem with my X3 on the Inspire 1, the only thing that solved the issue was putting the firmware on a blank SD card and install it again. Other than that message is there any image showing in the app, is the gimbal stabilizing or is it limp?
2017-2-8
timkkkk
Belgium
no image at all and gimbal is limp
2017-2-8
Robin UAV
Try putting the firmware on a blank SD card, insert it, power the aircraft and leave it for around 35-30 minutes. That should resolve the issue.
2017-2-8
timkkkk
Belgium
firmware update was ok now, GO app says "gimbal disconnected"
gimbal is limp and emit beep beep sound
2017-2-8
DJI-Jamie
Flight distance : 112405 ft
Since you're using a custom rig, none of the X3 data packages will be able to update the aircraft properly. The X3 can only be updated via an I1, OSMO, M600 or M100. The M600 adaptor plate when used with the N3/A3 with LB2 is a mod, so most likely a data package wouldn't be made available. You would want to look into getting in touch with a local dealer, or a friend with one of those platforms to get it updated.
2017-2-8
DJI-Jamie
timkkkk Posted at 2017-2-8 13:21
Could you happen to verify how you got the X3 updated? Did you receive a 'successful' .TXT message? Have you tried inserting a blank SD card and power cycling the unit?
2017-2-8
timkkkk
Belgium
DJI-Jamie Posted at 2017-2-8 16:18
i have this message:
Packet: MATRICE600_FW_V01.10.01.40.bin
Upgrading ...
Result: Success.
2017-2-9
timkkkk
Belgium
timkkkk Posted at 2017-2-9 12:35
this is the txt message when i want to upgrade with inspire 1 + inspire x3 firmware
Packet: WM610_FW_V01.10.01.40.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the device.
2017-2-9
DJI-Jamie
My concern is that you updated the unit with a file that also carries information for the M600's main controller. Does the N3 appear normal when you connect it to the Assistant 2?
2017-2-9
timkkkk
Belgium
N3 appears normal yes.
what do you suggest?
2017-2-10
Hazardpro1
When I put mine together I had same limp gimbal and beep beep.... turned out I did not have both leads connected to the Matrice board (1 to LB and 1 to N3).
PS also for what its worth I had firmware issue too and couldn't get any firmware to update via my rig (as Jamie advises above). I had to purchase a OSMO (handle) to enable me to install the OSMO firmware. Now the camera/gimbal works normal with no Firmware warnings.
H
2017-2-10
igorshiling
Russia
Prompt please, Dji N3 and Zenmuse H3-3D can work together?
2017-2-10
Hazardpro1
No it's not compatable with the 3D / 4D gimbals
2017-2-10
DJI-Jamie
igorshiling Posted at 2017-2-10 11:07
Hazard is correct.
2017-2-10
timkkkk
Belgium
DJI Jamie, N3 appears normal yes.
2017-2-11
timkkkk
Belgium
DJI Jamie, i have loaded osmo and M600 firmware through N3 X3 and gimbal works but no image transmission, i can take pictures
2017-2-13
Hazardpro1
If you have no picture try changing the settings in App, I believe I had to change the settings that related to how much processor/memory you allocate to the camera (or something like that) cant remember exactly what its called. But I had a dead picture too and it worked after I adjusted that.
H
2017-2-13
timkkkk
Belgium
Hazardpro1 Posted at 2017-2-13 08:04
H
nice Hazard, this works!! Thx!
2017-2-13
Hazardpro1
timkkkk Posted at 2017-2-13 08:21
Great stuff
2017-2-13
DJI-Jamie
Good to hear it got sorted.
2017-2-14
pratik12
India
Hi
I am facing a similar problem. My Zenmuse X3 Gimbal is limp and there is no video output to Dji Go App. The Dji Go App says Gimbal disconnected. Also there is no sound from my gimbal camera. I have used DJI N3+ Lightbridge 2 + Zenmuse X3 camera with m600 mounting bracket.
Please help me out with this issue
2019-3-12
