Charging 3 Mavic Batteries at the same time
4598 14 2017-2-10
fans593fc987
Flight distance : 508255 ft
(Youtube by Peter Homer Plublished on Feb 9, 2017)
Where to Purchase and reasonably priced.
2017-2-10
GSI_IRE
Flight distance : 121460 ft
Subscribed, just to see what everyone else's opinion is...
2017-2-10
Bradz
Flight distance : 62589 ft
I'm cautious about anything third party, it could void your warranty.
Subscribed.
2017-2-10
DroneFlying
Flight distance : 10774613 ft
Bradz Posted at 2017-2-10 05:33
Subscribed.
That's true, and even aside from the warranty concerns I'm a little leery of buying third-party accessories when the risk includes the possibility of a fire or small explosion.
One of my favorite things about the drone community is the large number of individuals and small companies who fill niches with innovative products. I'm happy to support those folks and have usually been very pleased with the value I got for my money, but it's one thing to stick a third-party ND filter on my Mavic and another to risk setting my house on fire. It may very well be an outstanding and safe accessory, but I'm not in a hurry to be one of the first people to find out.
2017-2-10
The Rev
Flight distance : 1256837 ft
I certainly wouldn't use it to charge the Batteries unattended but could be handy.
2017-2-10
Bradz
DroneFlying Posted at 2017-2-10 05:52
Even ND filters are risky, if they weigh a lot they could damage the gimbal.  Look at DJIs, thin little plastic things compared to the third party ones but I digress.
I personally don't see a need to charge 3 batteries at once, I wouldn't buy it even if DJI supported.  If Im out shooting I cant use this product anyway, only the car charger if I'm in my car and you rotate them round...
2017-2-10
Flipperman
Flight distance : 4224925 ft
Anyone from UK found a supplier for these ? (that's not located in China...).
2017-2-24
fans90d4f438
Flight distance : 451335 ft
this same charger has been in use for Phantom batteries for a few years. Most experience no issues.
I have one for my mavic and have been using it for a few weeks with no issues. Remember, the actual charging/balancing aspect is built into the battery.
But if you never have a need to charge more than one at the same time, then it's pretty useless for you
2017-2-24
Matman
Flight distance : 644669 ft
Or you could just use the new advanced charging hub. It pairs with the 100w p4 charger and can quick charge 4 at a time..
I have only needed to charge 2 at a time but will try all 4 soon, just to make sure.
2017-2-28
fans593fc987
Well I finally received this item from the manufacturer.  As warned by an independent source, the manufacturer does not connect the ground pin on the power source to the box.  So it requires you to open the box, solder a short wire from the ground pin to a screw on the box.  .  Although I made the modification, this does concern me none the less and I'm starting to wonder if I should even trust this charger.
2017-3-1
geofox784
Flight distance : 1482175 ft
I have one of these. I was worried about the charging not being as "smart" as the stock DJI charger. Maybe it doesn't balance the cells etc.... I did a little research and found the stock DJI charger and this are simply 13V power supplies. The circuit board in the battery does all the smart stuff like balancing the cells etc. Thus there is really no difference other than that this is basicly 3 DJI chargers in one.
2017-3-1
fans90d4f438
geofox784 Posted at 2017-3-1 06:47
instead of the research, you could have just read post #8 above. :-)
2017-3-1
geofox784
fans90d4f438 Posted at 2017-3-1 06:57
Unfortunately I am not a time traveller.... Did all of that weeks ago ;)
2017-3-1
Heavysledz
Flight distance : 819491 ft
Matman Posted at 2017-2-28 17:54
The advanced charger is still a sequence charger and will only charge one battery at a time. The only benefit is it will charge faster if toy pair it with a P4 wall or car charger. The charger in this thread is a parallel charger and can charge 3 batteries at one time.
2017-3-1
Matman
My advanced charger is charging multiple batteries at the same time.. or at least it was yesterday. I almost took a video of the 2 batteries blinking at the same time.
Edit, yup, it's charged the first of three batteries fully and the remaining two are now charging at the same time. So two at a time is the limit it appears.
2017-3-3
