RedHotPoker
Flight distance : 165105 ft
You need to cache the flight map while connected to a wifi network connection.
In the app is a tab Cache map in background, make sure that is turned on.
Bring up the map view, and slide it to the proposed flight area, where you plan to fly at.
Pinch squeeze the map to it's largest view. Scroll it around the area, beyond where you plan on flying.
After you finish, you can turn off your android device.
When you arrive at your flight area, the map should still be there, in the app.
It's not 100% effective, but most of the time it works very well.
Good luck, I hope it works for you.
& when you are back at home, and review the flight, you'll see the map in the background, regardless.
RedHotPoker
