Firmware update procedure for SSD reader
3471 4 2017-2-16
Coigreach
Flight distance : 546014 ft
Has anyone tried to check firmware update for the SSD reader yet?
According to the DJI CINESSD STATION Quick Start Guide, end of page 5 "Firmware Update" connect the station to a pc and launch dji assitant2. press the button (I'm assuming that's the button on the ssd reader) and release it when the update process is activated.
Not wanting to mess anything up! I'm not sure if the SSD has to be inserted or left out???
Any ideas?
Thanks
Karl
2017-2-16
nazar404.yahoo
Flight distance : 394291 ft
Nothing happen , I followed the instructions.
2017-2-16
DJI-Thor
Flight distance : 13602 ft
Since it's a firmware upgrade for the reader ,I can't think of reason to leave SSD in it.
2017-2-16
Coigreach
DJI-Thor Posted at 2017-2-16 22:25
Hi Thor.
Just was not sure page 5 of the cinessd  station manual has a' picture with the ssd in the card reader,  and' was not sure if the ssd had any sort of software that needed to be updated at the same time?
Karl
2017-2-16
Ivan Garcia
Flight distance : 3219157 ft
Mexico
By now, May 9, there is no updates for the unit, when a firmware update release, you have to push the button and then connect the USB 3.0 cable without release the button Until Assistant 2 recognizes the unit.
You can check periodically this document to know what firmware release has been published. https://dl.djicdn.com/downloads/ ... 2+Release+Notes.pdf
2017-5-9
