Difference with "broadcast mode" enabled?
2535 3 2017-2-21
edmoore
Flight distance : 598150 ft
Hi all, received my I2 and it's like a dream - just love it to bits.
One question - what difference does enabling "broadcast mode" make? This doesn't seem to be covered in manual or anywhere I can find online other than a vague marketing description that it's for outside broadcast etc.
The HDMI output still works fine with this mode off and you can set a clean output with no problems so it's not to do with that.
Does it enable some sort of priority video stream or improve delay etc?
2017-2-21
rowanhs
Flight distance : 400925 ft
Sorry edmoore i've been wondering this myself. Im replying to this to follow along with the post to find out the answer myself! Ill keep investigating and let you know if i find anything
2017-2-21
Dr Jon
Flight distance : 463012 ft
Under the "general settings"  you will find the Live broadcast platform for you to choose from, such as Youtube, Facebook, WeiBo or a custom RTMP. The BROADCAST MODE switch under image transmission simply enables the transmission when you want it to happen.
This all assumes you have Internet access on the mobile device to send the broadcast across.
2017-2-22
edmoore
Dr Jon Posted at 2017-2-22 00:19
Thanks Jon!
2017-2-22
