me personally i left it cool down then.. i recharge it.. if u need to get back right back out there i think u may need more batteries so u can keep flying..
Best to let it cool down, but unless you plan to use that battery straight away, there is no point in charging it immediately after. It is better to charge a LiPo battery just before you go out flying.
they should rest. mine seem to have a light blinking near the button diff from normal charging. when they cool down they charge fine. heat and lipos do not get along that is a cause for puffing, no not every one but increases the chances
It's really not recommended to charge the battery when it's still warm like that. The battery can be forgiving once or twice, but it could potentially reduce the life of that battery significantly if that's done constantly. It would be best to let the battery sit for a bit before charging it.
If you want to fly more then get more batteries. I have 3.
That means I could do 2 flights and by end second flight the first battery has cooled so it can be charged.
Some locations I go to have public bathrooms with power points.
My 4x4 has a 110v voltage point so I can be driving one location to another and charge a battery on the way.
