Phantom 3 Pro Drone Firmware 1.10.90 Video Transmission Problem
2905 23 2017-2-23
DroneTripping
This is a brand new in box Phantom 3 Professional I'm having issues with.
I knew I was going to need updates out of the box since it was purchased in 2015 but not opened/flown until now.  I had zero problems updating the RC to version 1.3.2 and then using the DJI Go app (DJI Go Version 3.1.5) to update the RC further to version 1.8.0
The issue is with the drone's firmware. I do not know what version it had initially, but I went to upgrade straight to the newest version 1.10.90 using the micro SD card in the drone per the DJI firmware update instrucations on the site/youtube. I got the appropriate D-D-D-D tones, but then eventually got the dreaded long D____ tone. To which I then powered down the drone and tried again. It started up again and this time went through the whole process faster but with the same end result.
I then found that unfortunately with this firmware update you cannot downgrade. I only found that out after trying to install 4 other versions of the P3P firmware with no success on various micro SD cards and everything.
After scouring online I can see nothing to fix this.  So, I'm coming here and praying there is a solution and that I haven't somehow managed to screw up my new drone.
Here's what I have observed so far:
The firmware shows as current and updated in the DJI Go app. You can see this in the images at the end of this post.
The RC and the drone appear connected. I think they are connected because I have a green light on the RC and I can move the camera gimble, arm/initiate the motors, etc. The only thing I don't have is camera transmission signal to my iphone 6.
Stranger, the text file says the update failed but in the DJI Go app it says I'm current.
I'm quite confused and would be happy for any assistance.
Initial view
Initial view
Final view
Final view
2017-2-23
denyed
Same problems with my P4!
Only my P4 thinks it's a P3P. Also no camera view. Very frustrating. I know DJI has a special wipe to fix these problems, why don't they share it with us?!?!
2017-2-23
Neves
Flight distance : 44872 ft
2017-2-23
DJI Natalia
Flight distance : 318 ft
Please post the hidden LOG file to us by following these steps:
1. Enable Viewing hidden files in your OS. Below are the websites where you can check how to show the hidden files in your PC.
For The Windows System: http://windows.microsoft.com/en- ... den-files=windows-7
For The Mac System: http://ianlunn.co.uk/articles/qu ... mac-os-x-mavericks/ 2.Enter the root directory of the SD card, then find the hidden folder MISC and enter it. There is LOG folder in it.
3.The LOG txt file is under the LOG folder.
2017-2-24
DJI Natalia
denyed Posted at 2017-2-23 14:29
You noticed the issue after a firmware update, right?
May I know you update it through APP or Assistant 2?
2017-2-24
denyed
DJI Natalia Posted at 2017-2-24 00:59
I initially used the APP to do the updates. But since then have tried the Assistant 2 with no luck.
2017-2-24
DroneTripping
DJI Natalia Posted at 2017-2-24 00:55
For The Windows System: http://windows.microsoft.com/en-us/windows/show-hidden-files#show-hidden-files=windows-7
[00014142][01 00] Firmware upgrade finished successfully.
[00014257]Done.
[00014289]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0xa0ce3fea].
[00014329]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014397]Version checking[2]...
[00014471][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00014551][03 06][00] v2.1.6.18 -> v2.4.20.28 need upgrade.
[00014587][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00014711][11 00][00] v1.6.0.0 -> v1.8.0.0 need upgrade.
[00014834][11 01][00] v1.6.0.0 -> v2.0.0.33, firmware v1.6.0.0 not support.
[00014867][11 01][00] v1.6.0.0 -> v2.0.0.33
[00014939][12 00][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00015024][12 01][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00015104][12 02][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00015223][12 03][00] v1.8.0.0 -> v1.11.0.0 need upgrade.
[00027759][15 00][00] device not detected.
[00027841][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00027960][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00028011][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00028044][01 00][05] v1.32.5432 -> v1.32.5432
[00028079][01 01][00] v1.6.2736 -> v1.32.5432 need upgrade
[00040610][08 00][00] device not detected.
[00040673][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00040706]Done.
[00040741]Firmware upgrading[2]...
[00040885][01 01] Firmware upgrade start...
[00071137][01 01] Firmware upgrade finished successfully.
[00071201][12 00] Firmware upgrade start...
[00139466][12 00] Firmware upgrade finished successfully.
[00139518][12 01] Firmware upgrade start...
[00204965][12 01] Firmware upgrade finished successfully.
[00205022][12 02] Firmware upgrade start...
[00268015][12 02] Firmware upgrade finished successfully.
[00268065][12 03] Firmware upgrade start...
[00334885][12 03] Firmware upgrade finished successfully.
[00334946][17 00] Firmware upgrade start...
[00482383][17 00] Firmware upgrade finished successfully.
[00482429][17 01] Firmware upgrade start...
[00555029][17 01] Firmware upgrade finished successfully.
[00555158][11 00] Firmware upgrade start...
[00605983][11 00] Firmware upgrade finished successfully.
[00606035][03 05] Firmware upgrade start...
[00678456][03 05] Firmware upgrade finished successfully.
[00678719][03 06] Firmware upgrade start...
[01045502][03 06] Firmware upgrade finished successfully.
[01048381][19 00] Firmware upgrade start...
[01058727][19 00] stop streaming timeout, continue upgrade.
[01203818][19 00] start streaming timeout, continue upgrade.
[01233859][19 00] Firmware upgrade finished successfully.
[01233924][09 00] Firmware upgrade start...
[01286014][09 00] Firmware upgrade finished successfully.
[01286078][04 00] Firmware upgrade start...
[01344513][04 00] Firmware upgrade finished successfully.
[01344547]Done.
[01344580]Version checking[3]...
[01344656][03 05][05] v34.2.0.9 -> v34.2.0.9
[01344733][03 06][05] v2.4.20.28 -> v2.4.20.28
[01344780][04 00][05] v1.48.0.0 -> v1.48.0.0
[01344896][11 00][05] v1.8.0.0 -> v1.8.0.0
[01345014][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01345047][11 01][00] v1.8.0.0 -> v2.0.0.33
[01345123][12 00][05] v1.11.0.0 -> v1.11.0.0
[01345247][12 01][05] v1.11.0.0 -> v1.11.0.0
[01345322][12 02][05] v1.11.0.0 -> v1.11.0.0
[01345402][12 03][05] v1.11.0.0 -> v1.11.0.0
[01357936][15 00][00] device not detected.
[01358018][17 00][05] v1.1.1.7 -> v1.1.1.7
[01358137][17 01][05] v1.0.2.7 -> v1.0.2.7
[01358194][19 00][05] v1.0.8.96 -> v1.0.8.96
[01358227][01 00][05] v1.32.5432 -> v1.32.5432
[01358262][01 01][05] v1.32.5432 -> v1.32.5432
[01370806][08 00][00] device not detected.
[01370874][09 00][05] v3.0.0.10 -> v3.0.0.10
[01370906]Packet upgrade failed at version checking.
[00014478]========== remo-con disconnect. boot(15) ============
[00014511]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce3fea].
[00014545]Packet upgrade start...
[00014582]Packet checking...
[00014630]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014788]Done.
[00014830]Version checking[1]...
[00014902][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014989][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015045][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015148][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015269][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015305][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015397][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015472][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015552][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015642][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028179][15 00][00] device not detected.
[00028252][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028373][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028432][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028477][01 00][00] v1.32.5432 -> v1.32.5432
[00028513][01 01][00] v1.32.5432 -> v1.32.5432
[00041053][08 00][00] device not detected.
[00041112][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041156]Packet upgrade failed at version checking.
[00014480]========== remo-con disconnect. boot(15) ============
[00014516]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce3fea].
[00014554]Packet upgrade start...
[00014598]Packet checking...
[00014637]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014703]Done.
[00014739]Version checking[1]...
[00014827][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014898][03 06][00] v2.4.20.28 -> v2.4.20.28
[00014945][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015060][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015178][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015214][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015327][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015406][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015506][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015586][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028140][15 00][00] device not detected.
[00028227][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028367][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028412][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028457][01 00][00] v1.32.5432 -> v1.32.5432
[00028569][01 01][00] v1.32.5432 -> v1.32.5432
[00041104][08 00][00] device not detected.
[00041174][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041211]Packet upgrade failed at version checking.
[00014519]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce3fea].
[00014602]Packet checking...
[00014642]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014707]Done.
[00014742]Version checking[1]...
[00014816][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014902][03 06][00] v2.4.20.28 -> v2.4.20.28
[00014951][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015082][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015222][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015257][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015350][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015450][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015651][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028188][15 00][00] device not detected.
[00028307][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028430][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028496][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028534][01 00][00] v1.32.5432 -> v1.32.5432
[00028570][01 01][00] v1.32.5432 -> v1.32.5432
[00041126][08 00][00] device not detected.
[00041179][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041215]Packet upgrade failed at version checking.
[00014496]========== remo-con disconnect. boot(15) ============
[00014532]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xa0ce3fea].
[00014570]Packet upgrade start...
[00014616]Packet checking...
[00014659]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014723]Done.
[00014760]Version checking[1]...
[00014848][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014935][03 06][00] v2.4.20.28 -> v2.4.20.28
[00014978][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015088][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015213][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015254][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015441][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015541][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015641][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015749][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028293][15 00][00] device not detected.
[00028397][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028539][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028589][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028634][01 00][00] v1.32.5432 -> v1.32.5432
[00028673][01 01][00] v1.32.5432 -> v1.32.5432
[00041210][08 00][00] device not detected.
[00041295][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041334]Packet upgrade failed at version checking.
[00014429]========== remo-con disconnect. boot(15) ============
[00014463]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0x287ca702].
[00014497]Packet upgrade start...
[00014533]Packet checking...
[00014567]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014636]Done.
[00014668]Version checking[1]...
[00014739][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014799][03 06][00] v2.4.20.28 -> v2.4.20.28
[00014848][04 00][00] v1.48.0.0 -> v1.48.0.0
[00014959][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015059][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015097][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015173][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015253][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015329][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015409][12 03][00] v1.11.0.0 -> v1.11.0.0
[00027950][15 00][00] device not detected.
[00028031][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028149][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028210][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028246][01 00][00] v1.32.5432 -> v1.32.5432
[00028286][01 01][00] v1.32.5432 -> v1.32.5432
[00040817][08 00][00] device not detected.
[00040889][09 00][00] v3.0.0.10 -> v3.0.0.10
[00040923]Packet upgrade failed at version checking.
[00015111]========== remo-con disconnect. boot(15) ============
[00015151]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x287ca702].
[00015263]Packet upgrade start...
[00015305]Packet checking...
[00015344]Packet vlink 01.09.0060 <-> 01.08.0080.
[00015410]Done.
[00015445]Version checking[1]...
[00015513][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015589][03 06][00] v2.4.20.28 -> v2.4.20.18
[00015636][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015729][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015829][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015864][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015944][12 00][00] v1.11.0.0 -> v1.10.0.0
[00016018][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016114][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016223][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028758][15 00][00] device not detected.
[00028858][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028978][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029024][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029059][01 00][00] v1.32.5432 -> v1.30.5036
[00029094][01 01][00] v1.32.5432 -> v1.30.5036
[00041630][08 00][00] device not detected.
[00041684][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041722]Packet upgrade failed at version checking.
[00015159]========== remo-con disconnect. boot(15) ============
[00015193]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x287ca702].
[00015226]Packet upgrade start...
[00015262]Packet checking...
[00015295]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015368]Done.
[00015401]Version checking[1]...
[00015472][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015547][03 06][00] v2.4.20.28 -> v2.2.6.19
[00015587][04 00][00] v1.48.0.0 -> v1.40.0.0
[00015639][09 00][00] v3.0.0.10 -> v1.7.0.3
[00015746][11 00][00] v1.8.0.0 -> v1.7.0.0
[00015825][12 00][00] v1.11.0.0 -> v1.8.0.0
[00015901][12 01][00] v1.11.0.0 -> v1.8.0.0
[00016004][12 02][00] v1.11.0.0 -> v1.8.0.0
[00016078][12 03][00] v1.11.0.0 -> v1.8.0.0
[00028613][15 00][00] device not detected.
[00028689][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028820][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028876][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028908][01 00][00] v1.32.5432 -> v1.23.3419
[00029036][01 01][00] v1.32.5432 -> v1.23.3419
[00041573][08 00][00] device not detected.
[00041606]Packet upgrade failed at version checking.
[00014351]========== remo-con disconnect. boot(15) ============
[00014386]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0x287ca702].
[00014420]Packet upgrade start...
[00014457]Packet checking...
[00014501]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014570]Done.
[00014605]Version checking[1]...
[00014673][03 05][00] v34.2.0.9 -> v34.2.0.9
[00014750][03 06][00] v2.4.20.28 -> v2.2.6.19
[00014794][04 00][00] v1.48.0.0 -> v1.40.0.0
[00014850][09 00][00] v3.0.0.10 -> v1.7.0.3
[00014972][11 00][00] v1.8.0.0 -> v1.7.0.0
[00015064][12 00][00] v1.11.0.0 -> v1.8.0.0
[00015139][12 01][00] v1.11.0.0 -> v1.8.0.0
[00015219][12 02][00] v1.11.0.0 -> v1.8.0.0
[00015305][12 03][00] v1.11.0.0 -> v1.8.0.0
[00027847][15 00][00] device not detected.
[00027941][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028062][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028111][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028150][01 00][00] v1.32.5432 -> v1.23.3419
[00028191][01 01][00] v1.32.5432 -> v1.23.3419
[00040727][08 00][00] device not detected.
[00040762]Packet upgrade failed at version checking.
[00014459]========== remo-con disconnect. boot(15) ============
[00014573]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0x287ca702].
[00014681]Packet upgrade start...
[00014796]Packet checking...
[00014892]Packet vlink 01.09.0060 <-> 01.08.0080.
[00014980]Done.
[00015048]Version checking[1]...
[00015134][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015219][03 06][00] v2.4.20.28 -> v2.4.20.18
[00015261][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015375][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015498][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015536][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015634][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015723][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015903][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016009][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028546][15 00][00] device not detected.
[00028639][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028759][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028809][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028852][01 00][00] v1.32.5432 -> v1.30.5036
[00028887][01 01][00] v1.32.5432 -> v1.30.5036
[00041423][08 00][00] device not detected.
[00041489][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041533]Packet upgrade failed at version checking.
[00014546]========== remo-con disconnect. boot(15) ============
[00014587]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xa0ce3fea].
[00014638]Packet upgrade start...
[00014683]Packet checking...
[00014726]Packet vlink 01.08.0080 <-> 01.07.0060.
[00014801]Done.
[00014845]Version checking[1]...
[00014936][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015016][03 06][00] v2.4.20.28 -> v2.4.14.5
[00015070][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015197][11 00][00] v1.8.0.0 -> v1.7.15.1
[00015307][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015404][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015504][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015609][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028149][15 00][00] device not detected.
[00028245][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028380][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028451][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028491][01 00][00] v1.32.5432 -> v1.30.5036
[00028532][01 01][00] v1.32.5432 -> v1.30.5036
[00041071][08 00][00] device not detected.
[00041131][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041171]Packet upgrade failed at version checking.
[00014766]========== remo-con disconnect. boot(15) ============
[00014804]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xa0ce3fea].
[00014843]Packet upgrade start...
[00014884]Packet checking...
[00014932]Packet vlink 01.03.0020 <-> 01.01.0009.
[00014999]Done.
[00015040]Version checking[1]...
[00015122][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015206][03 06][00] v2.4.20.28 -> v2.2.6.19
[00015357][04 00][00] v1.48.0.0 -> v1.40.0.0
[00015415][09 00][00] v3.0.0.10 -> v1.7.0.3
[00015562][11 00][00] v1.8.0.0 -> v1.7.0.0
[00015650][12 00][00] v1.11.0.0 -> v1.8.0.0
[00015755][12 01][00] v1.11.0.0 -> v1.8.0.0
[00015855][12 02][00] v1.11.0.0 -> v1.8.0.0
[00015955][12 03][00] v1.11.0.0 -> v1.8.0.0
[00028490][15 00][00] device not detected.
[00028586][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028738][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028796][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028837][01 00][00] v1.32.5432 -> v1.23.3419
[00028879][01 01][00] v1.32.5432 -> v1.23.3419
[00041420][08 00][00] device not detected.
[00041466]Packet upgrade failed at version checking.
2017-2-24
Neves
Natalia, yesterday, my P3 Pro show the same problem. Between a takeoff and another, in the middle of the afternoon, the video signal stopped working.
 And my P3 Pro have 2 weeks of life
2017-2-24
DJI-Thor
Flight distance : 13602 ft
Hi, OP, I'm sorry to say that you need to send it back.  The firmware upgrade stuck in the middle and there's nothing you can do to it.
2017-2-24
DJI Natalia
denyed Posted at 2017-2-24 06:39
Have you tried to reset it or downgrade firmware?
Would you mind trying other mobile devices to connect the aircraft to see the performance?
2017-2-25
DJI Natalia
Neves Posted at 2017-2-24 13:11
Sorry to hear about the issue, it's never hard landing, right? How about the firmware version?
Please try to restart the devices.
You used the original SD card, right?
2017-2-25
Neves
DJI Natalia Posted at 2017-2-25 20:03
I spoke to the support and after several attempts to do something, I had to send my drone to the DJI in Carson (Case Number: CAS-472815-T3C2Y4). Now I'm terrified that I'm leaving Canada on March 18th and I'm praying that they will return the drone with the problem solved before this date. If this does not happen I will have lost time and money.
2017-2-27
DroneTripping
Mexico
DJI-Thor Posted at 2017-2-24 20:00
Absolutely nothing? What the heck? I followed the procedure as it was listed perfectly. How do I know if it's covered? I literally opened the box and did the update the same day. I haven't even had this drone of the ground yet besides picking it up
I owned a P3S and felt very comfortable going through the process. How do you know it got stuck in the middle of the process? I'm assuming it's the internal SD card that is going to have to be messed with to fix it based on what you're saying. Is that correct?
2017-2-27
DJI Natalia
Neves Posted at 2017-2-27 14:49
We're aware of your case, and will take care of it.
2017-2-28
DJI Natalia
DroneTripping Posted at 2017-2-27 15:40
According to the upgrading log, two modules failed to be upgraded, it needs to be sent in and our engineers will help you evaluate it then get it fixed.
If it's product faulty and within the warranty, it will be covered by warranty.
2017-2-28
DroneTripping
Mexico
DJI Natalia Posted at 2017-2-28 00:43
Sorry it has taken me so long to get back to this. I have a few final questions:
First, how would I know if the product is within the warranty period or not? Do I need an original receipt or something?
Second, if it is not within the warranty what rough cost would you expect?
Last, how do I start this whole process to send it in? In other words, what do I need to do? Is there a page you can point to for directions?
2017-3-10
DJI Natalia
DroneTripping Posted at 2017-3-10 08:49
You need send in the aircraft to our service center, our repair engineers will evaluate why it failed to upgrade, then send you an e-mail with the invoice.
To start the process, please submit a case number and apply for pickup here: https://repair.dji.com/en/SelfRepair/Area
2017-3-11
DroneTripping
DJI Natalia Posted at 2017-3-11 20:13
Thank you both DJI Natalia and DJI-Thor for your help on this issue. I've gotten a case number (CAS-522032-L7F7J8) and will be shipping my drone back to the Carson, California DJI Repair Department as soon as I possibly can. It's hard with my work schedule, but I'm glad I can get the unit looked at and repaired. I'm hoping to actually fly this unit within the next couple of months.
2017-3-21
DJI Natalia
DroneTripping Posted at 2017-3-21 05:51
No problem, you will receive an e-mail with the shipping label in 1-2 business days.
Please feel free to let us know for any further questions.
2017-3-22
DroneTripping
Mexico
DJI Natalia Posted at 2017-3-22 00:38
Hi again. I shipped the drone out April 1 and per the "must be received in 30 days" comment I point to in the attached image, it felt like I should check in here. Considering I'm located in California I'm pretty sure DJI has had my drone for at least a week and it should be unpacked and examined. I don't see it showing as received or in process though. I thought it was a little odd the serial number, courier and tracking number weren't listed here as well. Is everything ok? Is there something more I need to do?
repair pic
repair pic
2017-4-11
DroneTripping
Mexico
LOL, disregard that last message. I literally received an email confirming it's arrival at DJI as I was typing that question/message.
2017-4-11
DJI Natalia
DroneTripping Posted at 2017-4-11 12:54
Thanks for your update, nice to know you got an update.
2017-4-12
fans5ec26613
Mexico
My p3p does not watch the video, then I could see, all this after the last update, you know if I still fail? Thanks..!!
2017-5-19
DJI Natalia
fans5ec26613 Posted at 2017-5-19 16:54
Sorry I am a little confused, could you please describe it in detail? Thank you very much!
2017-5-21
