looking for 1.8 firmware for Inspire Raw
2560 9 2017-2-23
bob_budowniczy
Poland
Has anyone of You have 1.8 firmware file?
I've uptated my aircraft to 1.9 whitch have a lot of issues so I have to downgrade inspire RAW.
I can't found any link on the DJI site and other places.
2017-2-23
tcchow
Flight distance : 9647812 ft
http://www.panorobot.com/dji/inspire_firmwares.htm
2017-2-23
Daroga
Flight distance : 3517287 ft
Zip file download from DJI @https://dl.djicdn.com/downloads/ ... FW_V01.08.01.40.zip
MD5 hash for .\WM610_FC550R_FW_V01.08.01.40.bin: 47e9d7cf0fb9929de5552217bec0bdba
2017-2-24
DJI-Jamie
Flight distance : 112405 ft
What kind of issues are you experiencing. Just to clarify, the latest firmware is v01.10.01.40.
2017-2-24
bob_budowniczy
Poland
Daroga Posted at 2017-2-24 13:19
Thanks! Problem solved
2017-2-28
bob_budowniczy
Poland
DJI-Jamie Posted at 2017-2-24 16:12
DJI Go app is not connecting with aircraft in latest firmware, I've done update on controllers also but it's not solved anything. Downgrade solved problem, every update after 1.2 is really bad. So I stay on 1.8 that long as I can.
2017-2-28
DJI-Jamie
bob_budowniczy Posted at 2017-2-28 06:21
To clarify, did you update the aircraft first and then the RC or vice versa?  When you're saying it's not connecting, do you mean that it won't allow you into the camera view or that when you do, it just says 'disconnected'?
2017-2-28
Donnie Stugots
Flight distance : 3636782 ft
You may have simply needed to do a relink once you updated the aircraft  and the RC.
sometimes they disconnect after an update.  When UPDATING , ALWAYS DO THE AIRCRAFT FIRST , THEN THE RC TRANSMITTER, IF YOU DONT , IT CAN GET VERY UGLY FAST .
donnie
2017-2-28
DJI-Jamie
If you haven't done it yet, please try Donnie's advice and see if it helps.
2017-2-28
djiuser_ZaIedhiRI4oA
Donnie Stugots Posted at 2017-2-28 09:44
Hi donnie,
I have seen you across multiple forums and am hoping you can help with my issue. I recently purchased an inspire 1 with an x3 and an x5. When initially launching dji go app and powering craft/ remote i was prompted to update the remote. Which i now see is not what i should have done. I then browsed forums to fix all the new issues that caused and rolled the rc firmware back to 1.6.0 and then updated my ac and x5 to the newest firmware 1.11.1.50 . I then finally had connection between the drone and rc but had a extemely laggy display on dji go app. I tested a recording anyways to be sure the x5 was in working order and everything looked great. I then saw i should update the rc in a forum and now have no image.
Also Im having an issue where the landing gear motor continuosly sounds like it is lowering and i have not been able to get the landing gear to engage once since purchased. I have also read and heard from dji support that this may be fw issue.
Thanks in advance!
2021-7-14
