Cetacean
Flight distance : 2528264 ft
Aloha mlash,
Your problem has the nVidia Shield K1 upgrade to Nougat 7.0 as a major component. So far I have been lucky but others are really having a hard time. Some have been able to roll-back to 6.0.1 (and lower) to wait out the solution.
In my case, everything is working real well except when I get anywhere near even what had previously been, the slightest interference. Somehow, in my case, only the real obvious interference is causing my app to shut down. Even during the precheck I am getting more and consistent warnings of interference.
There is something in the operation between DJI GO and Nougat that has made it very susceptible to interference. Look at your flying environment and see if there are sources of interference that you can avoid. Let us know if you find cause and effect.
Look on this Forum for the nVidia Shield K1 threads indicating your problem. They discovered the Nougat problem the day I upgraded my nVidia Shield K1! Fortunately I live in the mountain jungle and the only interference is obvious so I noticed that it was part of the problem.
Hope this helps!
Aloha and Drone On! |
