Inconceivable 7
Pakistan
Hi ricci,
Yes I am using go and gsp on ipad air 2 and hdmi monitor for video.
I am able to see the video feed in go app and hdmi monitor at the same time with the following settings
Slider 50%
Ext port enabled as LB2
app output LB2
Hdmi port enabled
Video type AV
Format 1080i60
But when I use gsp app then when gsp starts, monitor's video feed also stops and I can only see the overlayed flight data from the controller on the monitor. There are two options in gsp to select input video feed, HDMI or AV. I can only see the video on gsp window by selecting AV but even then unable to see video on monitor. There is no option to enable, disable or select Hdmi or sdi output ports.
I think that when gsp starts it reconfigures the video output settings for hdmi and sdi ports. There must be some provision to enable,disable and select video type for lb2 output port
