Donnie Stugots
Flight distance : 3636782 ft
Does it say disconnected on the go app status bar at the very top of the main app screen when you plug the RC into your LG v20 ? Have you tried another cable ? Can you get another device to load the Go app to ? This way you can make sure the HDMI on the back of the RC has not failed . They do fail on occasion .
Does the LG recognize that it is the Inspire that it is connected to ? If it is recognized the Inspire Aircraft wont be pointed at an angle on the start up, it will be facing you directly . Test this by opening the go app when it is NOT connected to the RC transmitter , you will see the Aircraft is pointing on an angle , when properly connected the Aircraft will be facing you directly .
First I would replace the cable
Then I would try another go app device ( I pad air and pro work flawlessly , need at least an A7 processor )
You may have a bad HDMI on the back the RC, which is about 90-100 dollars or the Phone you are using is no longer compatible for whatever reason, I know it worked in the past but the updates may have killed it , I don't know for sure .
good luck
donnie
