Carry Case for Inspire 2
7686 34 2017-3-2
fans593fc987
Flight distance : 508255 ft
2 questions because tech support could not answer them for me.
1. Does anyone know the dimentions of the case that the Inspire 2 ships with (in inches).
2. Does anyone know of a Pelican or Storm case that the Inspire 2 will slip right into when going on a plane.
I tried doing searches here on the forum but was not able to find what I needed so if there is a posting out there I beg for your forgiveness.
2017-3-2
fans6e0857a1
Flight distance : 5235886 ft
I got this one for my Ispire 1.  http://www.aerialmediapros.com/s ... n-storm-case/dp/711  I'm not sure if the Inspire 1 and Inspire 2 are the same size
2017-3-2
fans6e0857a1
I got this one for my Ispire 1.  http://www.aerialmediapros.com/s ... n-storm-case/dp/711  I'm not sure if the Inspire 1 and Inspire 2 are the same size or not.
2017-3-2
fans593fc987
fans6e0857a1 Posted at 2017-3-2 12:44
I got this one for my Ispire 1.  http://www.aerialmediapros.com/store/inspire-1-custom-pelican-storm-case/dp/711  I'm not sure if the Inspire 1 and Inspire 2 are the same size or not.
They are different dimensions but thank you for your information just the same.  Hoping to tap into someone that already has an Inspire 2 Case that can provide me with the dimensions of the Manufactures provided case.
2017-3-2
fans218d2672
Hi!
I use Peli 1640 that contains standard Inspire2 case inside it.
Andrei
2017-3-2
fans593fc987
fans218d2672 Posted at 2017-3-2 13:02
Hi!
Andrei
Thank you Andre!  Could I trouble you for the dimensions of your Inspire 2 Factory Case?
2017-3-2
fans593fc987
According to B&H the dimensions for the Inspire 2 Factory Case is 25.5" x 12.5" x 3.3" (L x W x H).  I'm finding it hard to believe that the external hight dimensions of the factory case is 3.3".  I'm hoping someone can chime in with this information.  DJI Technical Support could not provide this information.
2017-3-2
GabeZ
Flight distance : 768448 ft
Hello,
   I measured mine and this is what I get:
23.5" x 10" x 21.5" (L x W x H).
2017-3-2
Aeromirage
Flight distance : 1778045 ft
According to Case Pro, their I2 case will be:
Dimensions (in inches)
Interior: 24 x 24 x 14
Exterior: 26.5 x 26.54 x 15.65
https://caseproproducts.com/prod ... 2-landing-mode-case
2017-3-2
fans218d2672
fans593fc987 Posted at 2017-3-2 13:09
I could be wrong, because I'm not close to it now,
but the dimensions of the factory case are +- 60cmX58cmX28cm (LXWXH)
that in inches are 24"X23"X11" approximately..
2017-3-2
fans593fc987
fans218d2672 Posted at 2017-3-2 17:00
Perfect .... I used the conversion and came up with 23 5/8" x 22 53/64" x 11 1/32" so your measurements are right on!  Thank you very very much! Looks like the Pelican 1640 or the Pelican 1690 are the best fits to place the DJI Inspire 2 Case inside.
2017-3-2
fans593fc987
Hi!
Andrei
Andre .... one quick question about the Pelican 1640.  Do you know what your total weight is with the 1640 and the Inspire 2 together?  Trying to see if I can keep the weight under 50 lbs.  The 1640 weighs 34lbs.  If I carry on my batteries and Gimbal, I trying to find out what the Gross weight would be with the 1640 case.  Would you possibly be able to answer this?
2017-3-2
fans218d2672
fans593fc987 Posted at 2017-3-2 18:59
Hi!
I chose the 1640 because it is square and the factory case attached fine inside it with 2 cm of foam. In addition, at the top I screwed this organiser https://www.pelishop.es/pelicase ... -pelicase-1640.html for all additional items. About the weight i can't say now, will come back home on Monday and then will weight. But a lot, a lot! With two remotes, ipods, a bunch of batteries, chargers and other stuff.. Uff.. (everything is fit fine at the organizer, although it looks rough for me
2017-3-3
fans593fc987
fans218d2672 Posted at 2017-3-3 03:44
Hi!
I chose the 1640 because it is square and the factory case attached fine inside it with 2 cm of foam. In addition, at the top I screwed this organiser https://www.pelishop.es/pelicases-grandes/pelicase-1640trolley-es/organizador-de-tapa-para-pelicase-1640.html for all additional items. About the weight i can't say now, will come back home on Monday and then will weight. But a lot, a lot! With two remotes, ipods, a bunch of batteries, chargers and other stuff.. Uff.. (everything is fit fine at the organizer, although it looks rough for me
Thank you very much for getting back to me.  Because I am going to getting this case so that I can check the Inspire 2 on the airline, I will wind up removing the batteries and gimbal and putting that in my carry on.  I would be very much interested in your total weight so I can determine if it is possible to keep this case under 50lbs (airline weight limits) w/o surcharges.
2017-3-3
thomasakira
Flight distance : 921693 ft
fans593fc987 Posted at 2017-3-3 04:49
avoid surcharges forever.... https://www.idcreator.com/id-card-templates/press-pass
I fly 3-4 times a month with 6+ cases.... never had a single problem
2017-3-4
ScooterC5
Flight distance : 435052 ft
Also, don't forget that total dimension L+W+H must be less than 60" in order to avoid excess penalty fees...
2017-3-4
fans593fc987
ScooterC5 Posted at 2017-3-4 13:36
ScooterC5.  Thank you so much for reminding me about the total division restriction.  When I ordered my case this weekend, I ordered it in the Travel Mode configuration instead of the Landing Mode configuration.  This made a big difference on the dimensions of the case.  Much appreciated.
2017-3-6
WayneMann
Yes, I can confirm, oversize baggage fees at the airport are no fun when you travel with drones as much as I do.
Wayne Mann
2017-3-6
fans218d2672
Hi again,
The weight of the box filled completely is 33 kilos
when i put over all that possible (batteries, two remotes, chargers, iPads, camera, two lenses and so on) then i have 23 kilos that is exactly for aircraft limits. But i'm afraid that this case is much bigger with three dimensions that they permitted..
Andrei
2017-3-7
Coigreach
Flight distance : 546014 ft
Just to be exact  my I2 case is 590mm x 535mm x 255mm
2017-3-7
Mike-the-cat
Flight distance : 22488593 ft
fans218d2672 Posted at 2017-3-7 15:37
Hi again,
You are NOT allowed to check in batteries. DON'T ever do that.
2017-3-7
Mike-the-cat
US bag handlers must be very rough. I've traveled with the stock I2 case as I'm sure others have. Put 'Fragile' tags and so far, no problems.
2017-3-7
fans593fc987
Hi again,
Thanks for the info!
2017-3-7
RichHowellNJ
Coigreach Posted at 2017-3-7 17:53
This equates to 54.33 Inches in total dimensions so that would have no troubles getting through TSA for checking.  Which case are you using again?
2017-3-9
Coigreach
RichHowellNJ Posted at 2017-3-9 04:02
I2 case.... the one that it comes with.
2017-3-9
JonCahillPhoto
Flight distance : 15256 ft
Mike-the-cat Posted at 2017-3-7 18:21
Great tip on the Fragile tags. I seem to recall some technical specific tags to apply when I was early on in my Telecomm years. Something along the lines of "Sensitive Electrical Equipment" or the like helped to stress, or label as a target, for the handler(s).
I am looking forward to the GPC case that we ordered at work to arrive next week. Different model Inspire though.
2017-3-9
RichfromHowellN
Coigreach Posted at 2017-3-9 04:20
I would be afraid to check that case.   This is why I ordered to Go Professional (Travel Version) Case.  It is about 4" in total width too big.  Hopefully the airline will not give me a hard time.
2017-3-9
Coigreach
RichfromHowellN Posted at 2017-3-9 09:36
I realize that but was replying to your original post question (1. Does anyone know the dimentions of the case that the Inspire 2 ships with)
2017-3-9
ScooterC5
Mike-the-cat Posted at 2017-3-7 18:20
Actually you're allowed to check the batteries that are installed in the Inspire.  Installed batteries are the only ones you're allowed to check.  So you can legally check two Inspire 2 batteries as long as they're installed in the drone.
2017-3-9
Mike-the-cat
New Zealand
ScooterC5 Posted at 2017-3-9 10:28
This rule doesn't make sense to be honest. Given that Lithium batteries have a low but finite risk of catching fire spontaneously, why would it be safer if the battery was installed compared to if it were not ?- since the former is unequivocally, an open circuit and the latter, true only if there is no malfunction.
Should a fire erupt, wouldn't it be safer if it were in the cabin and detected by many humans, rather in a hold which is not accessible to witnesses and more importantly, agents who could control a fire?
I believe the current rules were set up to allow the air-shipping of equipment like laptops, tablets and phones that have batteries integrated in their chassis. Do recall that 2 years back, some poor quality personal mobility devices with installed batteries caught fure in flight. Its the latter fly-by-night manufacturers that have tarnished the market and have resulted in tightened regulations.
Overall, the risk of a spontaneous fire from a well conditioned new Li battery that is not at full charge is very very low. Rule-makers are not perfect nor are they always logical and business concerns sometimes color the way rules are made.
Hope this clarifies
2017-3-9
Mike-the-cat
New Zealand
JonCahillPhoto Posted at 2017-3-9 07:36
On some airlines, fragile cargo is put in a different section on the aircraft.
The advantage of the original case is that it is very light. If you are on the move, lugging a large heavy albeit more secure case is not fun.
2017-3-9
ROCStudios
Flight distance : 45679 ft
thomasakira Posted at 2017-3-4 12:19
Does it really work?????
2017-3-14
thomasakira
ROCStudios Posted at 2017-3-14 11:50
I am a super honest person,  but I found it crazy that I needed "media" ID to get the media rate.... like why else would I have 8 peli 1620s.  So I decided to try and make an ID, and in the process of getting the laminates I found several of these ID companies.
Does it work...absolutely positively yes,  I have the one with the mag strip and bar code...works every time.
2017-3-15
ROCStudios
thomasakira Posted at 2017-3-15 06:42
super impressed!  hey!  thats awesome savings right there! I did not even know they had such thing as "Media Rate" - I wonder if it works for international travel, as I travel 6 to 7 times a year international.
2017-3-15
fans91d51e14
Hi!
Andrei
Hi Andrei,
Just to confirm. The original Inspire 2 case fits directly into the Pelican 1640?
Thanks
2019-6-21
