Donnie Stugots
Flight distance : 3636782 ft
SteveSA Posted at 2017-3-5 06:23
Hi Donnie
Ive been running the motors without blades the whole weekend and I haven't picked up anything as yet with a motor loosing power..i am dumb struck of what it is.....
No , what I mean is as the booms are raising , it may have a chaffed wire or something , or the ESC is faulty .
If a motor was faulty , I am not sure if not having the load on the Motor without props would stress it out . You couod test the nmotors if you happen to have one of those laser temp gauges, I use those all the time to check my motors, in case one was getting to hot .
Try raisng the gear up and down and see if one of the motors caughs or anytnhing . I would hold it in the air , props off and cycle the gear to see if anything funky happens .
The crash was so sudden and if the battery ( checked out OK ) was OK , I suspect a Motor momentarily lost power and down she came .......this is just a guess of course .
good luck
donnie
