P4 controller won't fully charge
810 5 2017-3-4
mic75
Flight distance : 3799423 ft
my controller will only charge to 75%, the charging lights go out as if it's fully charged but it's not. if I plug it back in it will start charging again but still not fully charge.
can't leave it on to flatten the battery because it turns off, any thoughts.
2017-3-4
Quamera
How old is the controller. I don't know how long warranty claims take from here but I doubt if it would be quick unless you have a tame retailer to do a swap.
It could easily be a failed cell and unfortunately I don't think DJI will sell you a new battery for a DIY fit. Try a flight with a decent clear space around the home point so if the controller battery dies suddenly the AC can RTH safely (check your RTH settings first).
If the battery drops from 75% to 50% or below during the flight you definitely have a battery problem, if it holds above 50% its probably more a charge controller problem and you can still fly with confidence because a good 75% battery can still do several flights safely.
2017-3-4
WilliamM
Flight distance : 904364 ft
Use it like normal, time after time without charging it at all. Let it get down as low as you dare, then try charging it.
2017-3-4
mic75
Quamera Posted at 2017-3-4 15:24
It's about 6 months old, I noticed it dropped down quick as well. I will have to force myself to fly my drone a lot{:4_157:} to test it.
2017-3-4
mic75
WilliamM Posted at 2017-3-4 15:26
I will do hat
2017-3-4
DJI Natalia
Flight distance : 318 ft
We replied you in your another thread, very sorry to hear about the problem.
2017-3-6
