fans328e606e
Greece
Hi, when you are in manual operation, and before you set the A point, you must spray as a test for the spraying system, for a few seconds. Then the red led in the tank condition indicator will turn to green. When it is green you will be free to set the A point. I suppose it is a fail safe operation, in order not to start spraying in smart operation before checking the spray system. I hope i helped! |
