firmware update 2times flight after x4s error
2078 18 2017-3-5
Jack Do
South Korea
i dont know. why not x4s booting motion?
no crash...
but video signal is ok...
cant cal and control...
2017-3-5
Jack Do
South Korea
2017-3-5
Dr Jon
Flight distance : 463012 ft
I have seen this on other forum sites. Suggest you follow what they did. Basically they went back to the Assistant 2 web page and did a "restore factory settings" then with the camera attached reloaded the firmware. Also make sure you have the latest version of DJI GO 4 loaded AFTER you have deleted the older version and restarted both the Mobile device and Reboot the R/C.
2017-3-5
Jack Do
South Korea
Dr Jon Posted at 2017-3-5 20:30
im already re firmware and factory reset.. same error...
2017-3-5
DJI-Jamie
Flight distance : 112405 ft
Jack Do Posted at 2017-3-5 22:15
Have you also tried an IMU calibration, then a gimbal calibration in that order? Are you still able to connect to the Go4 app? When you try a gimbal calibration, did you see any response or error messages?
2017-3-5
fans1d6b7d4d
Flight distance : 436640 ft
I to also have the same issue.
So here is what happened . I updated The inspire 2 to firmware V01.00.0240, After the updated completed the X4S Camera Gimbal had gotten stuck. I recalibrated the IMU then tried to calibrate the Gimbal to no avail. Reset drone multiple time and will not do the gimbal dance on start up.
After that did not work, I restore the unit to factory reset then installed the update again. Then did above troubleshooting steps above to no luck. Also spoke to DJI customer support and they were not much help at all saying the best thing to do is send the camera back from where I purchased it.
2017-3-5
DJI Natalia
Flight distance : 318 ft
Thanks for your feedback, I've reported it to our engineers, will get back to you soon for any news.
2017-3-6
fans2788a923
Flight distance : 24767 ft
On Tuesday morning, I have the same issue. The X4S will not boot and is stuck. I've been waiting for a technical representative to come on the line for more than 30 minutes now. I do not understand why DJI can't get its act together. The drones are innovative but replete with quality control issues. Recent firmware updates cause more harm than good. And the customer service is just awful. Long hold times. Incomprehensible representatives who appear to lack product knowledge. And the more DJI drones you buy, the worse connecting with them gets.
2017-4-11
fans2788a923
2017-4-11
fansc312fdf8
That exact same thing is happening on my x4s. It can't be a coincidence that so many users are having the same exact issue. I have picture, but no gimbal and it's rolled 90'
2017-4-15
GabeZ
Flight distance : 768448 ft
Hello,
   What about the new firmware V01.0.03300? Did it fix it?  I was never able to test as I sent my camera in for a replacement refurb.  I can confirm, however, that the x4s camera stayed working after V01.0.033001.0.0330.
2017-4-15
Julien
Ghana
any updates on this ?
I have same problem,
suddenly, it all worked fine, didn't change anything, and the next morning, boom, it happens...
I am now in Africa for shooting, if any solution please tell...
2017-5-2
Julien
Ghana
HEY DJI, Ding Dong, Ding Dong,
Get ya sht together, and at least tell us WHY it happend!,...
We aren t novices, we know equipment trouble, and if there is one, need to know WHY ! Now we don't have any idea, cant explain to the client nothin;....
We're in trouble here, we don't spend 15k with you guys, and then not to be able to use it, on far away shoots on continents without any service center, or any of yr models being here!!!...
GET YR SHT TOGETHER, If yr selling to Profs, ya need a Prof Help desk 24/7 not a bunch of ... with no product knowledge, probably no idea what a quad copter is, that search the Forums!
Equipment should be able to be send anywhere in the world within 24h...!!!
We're loosing sht loads of money here!!!  I would never have this problem with Leica or Arri ....
2017-5-5
fans21dd7ed2
Flight distance : 212044 ft
Exact problem here. X4S rolls 90 degrees to the stop and freezes along with yaw locked. Pitch is free and unresponsive.
Updated through GO 4 app.
2017-5-30
fans21dd7ed2
Today's trouble shooting with no improvement:
   1. Calibrated IMU via Go 4 app connected to RC.
   2. Firmware "refreshed" via Assistant app v4.1.0 on a Mac.
   3. Downgraded to v01.00.0240 via Assistant.
   4. Firmware compatibility warnings on boot up, Downloaded as requested by GO 4 app.
   5. Went back to Assistant app and upgraded FW to v01.00.0330
   6. Went through all my settings again and x4s is still bricked.
2017-5-30
jburkett
guys, sorry for that, please contact the DJI service for repairing,  we have already find out the reason and fix it, but the machines that have already got this problem can only be repair by dji service ( which needs to be tear-down and reprogrammed ), sorry for that... TAT
2017-6-1
Lambrechts
jburkett@zackbu Posted at 2017-6-1 03:03
Dang! I just hit this same problem... Do I really have to send it in to get fixed still?
is there no way I can reset otherwise?
Thanks in advance!
2017-9-9
Lambrechts
UPDATE! I FOUND A FIX FOR THIS!!!
Okay, go to
http://www.dji.com/inspire-2/inf ... a6cc123a8#downloads
Download the 'DJI ASSISTANT 2'
Plug your unit directly into the computer (DO NOT USE IPAD OR PHONE / APP) open the program on your Mac or PC turn on Inspire and follow directions to 'restore factory preset/settings'
Then load the firmware again directly from the computer! it worked 100%
Resetting my camera again!! no problem at all (for now)
Message me if you have any problems with it!
2017-9-9
Lambrechts Posted at 2017-9-9 13:30
Okay, go to
Lambrechts, sorry for the late response, we are glad to hear the problem got sorted out, expecting more wonderful pictures and videos from you.
2017-9-9
