Is this what is meant by "watercolor" video?
2127 25 2017-3-6
TimmysDad
Flight distance : 1412917 ft
Flying conditions were not ideal today but I wanted to fly my new Mavic and take some video.  The settings were 3840x2160, 24 fps and the file was saved as a  mp4 file.  The white balance was set on automatic.  A portion of the video is attached.  I'm somewhat disappointed in the quality of the video, specifically the branches of the trees.  Is this what I've seen mentioned as "watercolor" or "jello" results?  The branches of the trees are totally without detail - if you notice the orange colored tree branches, they are the worst.  The branches appear as smudges.  Is this normal?  Are there settings that will correct this?  Or possibly better light?  I've taken quite a bit of video with my Phantom 4 and have never seen, or noticed, video that looks like this.
Thank you for your comments,
Don
2017-3-6
dronist
It is NOT like the P4. You need to tap to AUTOFOCUS and or use manual focus.
2017-3-6
Ex Machina
Flight distance : 1806362 ft
Jello, I think, is a wiggly look and is due to undamped vibration of the gimbal.
This does look like the watercolor issue some have reported. I wouldn't have expected to see it in this kind of light, though, so by chance did you have your sharpening turned down?
2017-3-6
geofox784
Flight distance : 1482175 ft
Looks like Colorado?
2017-3-6
TimmysDad
dronist Posted at 2017-3-6 18:06
Yes, I am aware of the need to focus and it was focused on the trees.
2017-3-6
TimmysDad
Ex Machina Posted at 2017-3-6 18:27
I'm not sure of where I'd turn the sharpening down.  I'll check the manual before I can give a response but in general, I'm pretty sure I didn't make any adjustments for sharpening.
2017-3-6
TimmysDad
No, Kalispell, MT.  We've had quite a winter and I'm ready for something other than a gray sky and white ground.
2017-3-6
geofox784
TimmysDad Posted at 2017-3-6 18:49
"I'm ready for something other than a gray sky and white ground."
Same goes for here in CO
2017-3-6
Ex Machina
TimmysDad Posted at 2017-3-6 18:48
It's in your Camera's Style settings, a negative value for the triangle means less sharpening.
Assuming you are also using the default video color profile and the Standard Style settings, you could try resetting your camera settings, which on iOS is the last option in the settings under the gear icon.
2017-3-6
Sangarone
I definitely have the same problem with bare tree branches... Especially if the video is focused on something like a house/building, trees in the peripheral are totally fuzzy.
2017-3-6
Ex Machina
Here's what the standard, default settings look like on my Mavic, taken yesterday admittedly under better light, but if you look through the set on Flickr there are a few under subdued lighting conditions and none of them approach what we see in the OP's video.
DJI_0424 by Lewis Francis, on Flickr
2017-3-6
TimmysDad
Ex Machina Posted at 2017-3-6 19:14
[view_image]
Thank you - I'll check that setting. I believe I watched a video of the "best" video settings for the Mavic and a negative value was recommended as part of a custom setting.
2017-3-6
Ex Machina
TimmysDad Posted at 2017-3-6 21:36
So I think less sharpening is maybe better when you want to control the sharpening later in post, and I do believe the standard sharpening is maybe a little aggressive sometimes, but in low light, negative sharpening works against you due to DJI's noise reduction algorithms.
Not sure that's the problem here, but an avenue to explore, anyway.
2017-3-6
Bennettmike
Flight distance : 227585 ft
Ex Machina Posted at 2017-3-6 19:25
Thanks for the post, I always forget to use my Flicker account.
2017-3-6
Could you please reset the camera settings and test more?
If convenient, please upload some original videos to dropbox and send me the link. I'll help to check it.
2017-3-7
Dazba
Flight distance : 17188 ft
I had the same problem with my first videos, no detail in the tree tops. I then changed my custom camera settings to Sharpness 0 Contrast -1 Saturation +1 and colour space to D-Cinelike. You may also find that you have to reboot the camera for changes to take effect. To reboot change from pal to NTSC mode then back again. I do not do any colour grading yet (noobie) but the results I get with these setting are superb.
2017-3-7
Watty2000
Flight distance : 1074301 ft
Yup, looks like the dreaded watercolour issue I and countless others are experiencing. Flew three flights this morning; on the first and second, all fine detail looks good. Then, without changing anything, on the third flight, the branches of the trees just look like ill-defined smudges.
2017-3-7
TimmysDad
Dazba Posted at 2017-3-7 00:49
Thanks, I'll give those settings a try.  I just hand held the drone and took some video of the trees outside and they appear to be fine - I'd changed the settings to the first default settings which are zero's for the three items.  Still to cold to fly this morning, about 20 deg F., but when it warms up I'll try it again.
DJI Mindy - I'll do as you suggested and post some video a little later.
2017-3-7
rydfree41
Flight distance : 153268 ft
Wow that doesn't even look in focus at all . Even the building and the fence look like crap . I'm glad mine has been fine .
2017-3-7
Bintryin
Flight distance : 164406 ft
Water colour can appear when you have under exposed the image . which the trees in this video are underexposed . also focus helps
2017-3-7
TimmysDad
OK, I shot a little more video today - it was cloudy and snowing again so very similar to yesterday's video.  The only change I made was to the video setting for sharpness, contrast and saturation.  Yesterday's sharpness setting was -2 and today the setting was 0.  There is a significant difference in the sharpness and "watercolor" effect.  There are a few instances where there is a slight "watercolor" effect.  At the beginning of the video there is a Ponderosa Pine (the last tree at the bottom of the driveway) that has a little of the effect.  At about 20 seconds there are two scrawny fir trees with a little of the watercolor effect.  It seems that the closer the tree, the more noticeable it is.  Trees farther back, do not show any of this effect that I can distinguish.   For me, I'm going to leave the sharpness at 0 as suggested earlier.
Thanks for your comments.
2017-3-7
Ex Machina
TimmysDad Posted at 2017-3-7 17:39
Short video shot today with different sharpness setting.
Glad to hear of the improvement -- wait till you see it how it performs in strong light!
2017-3-7
TimmysDad
Ex Machina Posted at 2017-3-7 19:21
Thank you for your comments and knowledge about this subject.  It made a big difference and shortened the learning curve greatly.
Don
2017-3-7
GravitonPhotogr
Flight distance : 125210 ft
Way better now.
2017-3-7
DJI-Thor
Flight distance : 13602 ft
This one seems much better
2017-3-7
Dazba
WOW, that's a big improvement. You will find that the video quality is much better on good bright days. Roll on Spring hey
2017-3-8
