help my p3s fell out of the sky
1598 29 2017-3-9
speed3
I was flying my phantom 3 standard when it all of a sudden said signal lost, and it fell from the sky. Needless to say the drone is pretty much destroyed. I will upload the log maybe someone here can tell me what happend. I didnt see it go down so not sure if someone shot it down or not.http://www.phantomhelp.com/LogViewer/Y19NVUH9TC2DTK10F9QR/not sure if that was the correct way to attach the log any help would greatly appreciated thanks.
2017-3-9
Maxi3D
Flight distance : 307621 ft
Is there any bird shots inside the Phantom?
2017-3-9
speed3
Maxi3D Posted at 2017-3-9 11:58
im sorry what do you mean by bird shots inside
2017-3-9
Maxi3D
I mean any shotgun pellets inside the drone.
2017-3-9
speed3
nope there isn't but i just dont understand how else it could of went down.
2017-3-9
Betamace
Flight distance : 2133 ft
The last update took 4.5 seconds. That is very unusual.
2017-3-9
speed3
Betamace Posted at 2017-3-9 12:40
so you think i should send this to dji what would they be able to do?
2017-3-9
nilmaster
Flight distance : 232707 ft
For some reason your Home Point changed at 33 sec into the flight. Home distance was 36.3 feet and changed to 238.9 feet away from home in less then .1sec
2017-3-9
Jake Phantom 3
Flight distance : 2639747 ft
Starting at 3 min 4.3 seconds your speed was 22 mph and going down every second. By the time it stopped recording at 5 min 10 seconds it was going at .7 mph and at 170ft altitude. You had been losing altitude since around 4.56 minutes. Couple questions, were you bringing it down yourself? Looks like a loss of power, bad faulty battery maybe? I'm no expert, just my opinion.
2017-3-9
speed3
Jake Phantom 3  Posted at 2017-3-9 13:38
yea i was bringing it down a little to take a better picture but was defiantly still high enough to clear everything. I thought the same thing about the battery but when i found it battery was still powered on. thanks for all  the replies by the way
2017-3-9
Taydav
Flight distance : 115328 ft
What was the outside temp? It looks like it's reading 0 degrees f.
2017-3-9
RedHotPoker
Flight distance : 165105 ft
Hey, sorry to read about your crashed drone. Not sure what caused this malfunction.
Perhaps sending it in, DJI will have the ability of finding the true cause.
Best wishes...
RedHotPoker
2017-3-9
speed3
Taydav Posted at 2017-3-9 14:39
temp was around 50 f. where do you see 0? and not sure if it matters but winds were 5-10 mph at most
2017-3-9
speed3
RedHotPoker Posted at 2017-3-9 14:47
yea thanks it does suck and i sent them the log ill let you guys know what they say
2017-3-9
RedHotPoker
speed3 Posted at 2017-3-9 15:03
Yes, there's not much more that you can do now. Trust that they will give you the honest evaluation.
Did you try sending the flight LOG to www.phantomhelp.com
www.phantomhelp.com/LogViewer/Upload
You are at the mercy of DJI. As we all are. ;-)
Best wishes, and good luck...
RedHotPoker
2017-3-9
Taydav
speed3 Posted at 2017-3-9 15:02
Without going back into the log I thought I saw that the temp was a vonstant 0 degrees
2017-3-9
Sorry to hear about your crash.
I'd suggest you to send it in and our engineers will help to analyse the flight data and let you know what could have caused the issue.
You could fill in an online repair request form and apply for pickup here.You’ll get a case number automatically https://repair.dji.com/en/SelfRepair/Area
2017-3-10
Impulse
New Zealand
If you look carefully, from 24 seconds to 5:10 the battery remains at 93% which doesn't make sense to me. That is 22.27% of the rated battery life of a fully charged battery (25 minutes assumed). You would expect the battery to go down by about 70% - 75% in that time. Sounds like a faulty battery to me.
2017-3-10
Impulse
New Zealand
*You would expect the battery to go down to between 70-75% in that time given that you started with 94%.
2017-3-10
Aardvark
Flight distance : 384432 ft
Looks like the system was wrongly reporting the battery capacity and it just ran out of power. Hopefully DJI Technicians can provide some detail as to why this happened.
2017-3-10
blackcrusader
Flight distance : 689774 ft
Taiwan
Aardvark Posted at 2017-3-10 05:01
Good observation of the log.  I think his drone has landed in the back yard of a house that looks like it has a pool.
POOL
POOL
2017-3-10
speed3
blackcrusader Posted at 2017-3-10 06:06
yea faulty battery seems to be most logical reason. and it fell on a concrete step drone is destroyed
2017-3-10
speed3
DJI Mindy Posted at 2017-3-10 00:51
yea they told me to send it in. only problem is i have a dbs antenna on the controller not sure if that will void warranty, and i know that was not the issue with it falling
2017-3-10
speed3
also i see some dents on the battery that weren't there before but the battery never came out of the drone so i dont know why it would be dented there.
2017-3-10
blackcrusader
Taiwan
speed3 Posted at 2017-3-10 19:14
You are sending the drone and battery not your RC.
If it is a faulty battery DJI would see that.  Dent's on the battery probably happened when the drone crashed.
2017-3-10
speed3
blackcrusader Posted at 2017-3-10 19:57
on the form it says to send in drone and rc but yea they dont need the rc so i most likely wont send that in
2017-3-10
Blaize Films
Nigeria
Please try keep us updated so we can know what really happened
2017-3-10
JackA
Flight distance : 32057 ft
Sorry to say, but they call these a "system" because the battery, controller and the aircraft all have a roll in flight.  To be honest, you should send every component just as you flew it.  You are asking DJI to stand behind their product, so you should not try to maintain that modifications you applied are not the cause or a contributing factor to the crash.
2017-3-10
After the evaluation, our engineers will let you know if it's covered under warranty.
2017-3-12
blackcrusader
Taiwan
Thanks Mindy.  Very informative.
2017-3-12
