I just shot my first video(s) today after the update (3/10/17), and it seems like the file that was shot is incompatible with the newest vegas 14 pro editing software. All my other files, both h.265 and h.264, work perfectly fine on vegas. This update might be a problem... EDIT
.mov files work perfectly fine. DJI please do something about this mp4 file for firmware updated users.
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L5@High
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Duration : 5 min 27 s
Bit rate : 99.9 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.502
Stream size : 3.81 GiB (100%)
Title : DJI.HVC
Language : English
Encoded date : UTC 2017-03-10 12:30:37
Tagged date : UTC 2017-03-10 12:30:37
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Other
Type : meta
Duration : 5 min 28 s
Default : No
Bit rate mode : VBR
Vegas Info:
General
Folder: C:\Users\tomlu\Desktop
Type: AVC
Size: 4.00 GB (4,091,634,495 bytes)
Created: Friday, March 10, 2017, 2:38:24 PM
Modified: Friday, March 10, 2017, 12:36:14 PM
Accessed: Friday, March 10, 2017, 2:38:24 PM
Attributes: Archive
ACID information
ACID chunk: no
Stretch chunk: no
Stretch list: no
Stretch info2: no
Beat markers: no
Detected beats: no
Other metadata
Regions/markers: no
Command markers: no
It might be worth making a short piece of material and sending it to Magix so they can work out why it won't load, DJI don't actually make their own codec.
Geebax Posted at 2017-3-10 21:31
That might be a good idea. Either way, DJi did something since every other video from my p4p works with vegas besides mp4 (h.265) files after the firmware update.
