Centre of Gravity for M600
4745 10 2017-3-11
ricci2
Flight distance : 61158 ft
Hi all M600 owners,
I have been asked to help find the COG, centre of Gravity for a M600 pro but I am trying to get the drawing for that; however, in the meantime I have calculated the M600 COG for anybody who needs it. It will be +- a few mm because the weight will be different depending on your crafts addons. All measurements for the craft are taken from the bottom plate as shown by the small white marker, it is the drawing start origin and not the centroid of mass. You might notice the X, axis has a 2.9 mm offset, this is due to the compass placement I guess.
One proviso must be taken into account is the weight of the electronics and batteries, this is for a standard battery and single IMU and no gimbal, plus it needs the drawing supplied by DJI to be correct to extrapolate the figures, always a get-out clause!
Hope that helps anybody who needs this type of spec and could not find it.
DJI have a figure of 26mm in the Y, axis acording to the setup of the internal IMU, I dont know if this is the COG or Centroid of Mass, they are diferent beasts and so I suspect its C/Mass because they dont know what camera is fitted and C/Mass is not calculated using the weight of the craft, just geometric locations.
If you think there is an error please feel free to point it out, always happy to learn.
X,=2.9   mm, red
Y,=-52.3 mm, green
Z,=1.4   mm,  blue
ricci
2017-3-11
Sestaceans
Flight distance : 3963865 ft
Thanks for this @Ricci
2017-3-13
fans5659ff45
Flight distance : 189593 ft
Belgium
Hi Ricci, I need to do the same for my DJI Inspire 1 so I can add it to my Operational Manual. But as I'm not a science boy, I don't know where to begin... Can you help me?
2017-12-18
fans5659ff45
Belgium
Hi Ricci,
Can you help me?
Kind regards, Matthias
2017-12-18
ricci2
fans5659ff45 Posted at 2017-12-18 05:19
Hi Ricci,
Hi,
I can help but you need to see if there is a cad drawing on the download section of the inspire page.
if it has dimensions it can be calculated.
let me know what you find.
all the best
ricci
2017-12-19
cagiva851
ricci2 Posted at 2017-12-19 17:01
Hi,
Hi ricci,
Which application are you using the shows that iProperties dialog with the Mass, Area, and Volume input data?
2018-9-17
ricci2
cagiva851 Posted at 2018-9-17 13:11
Hi ricci,
hello,
I use Autodesk inverter 2018, you can also use finite analysis programs to from Autodesk and Catica.
hope that helps
2018-9-17
ricci2
Hi Ricci,
sorry for not getting back to you sooner, you first need a precise cad drawing, dji had one for the matrice 600 on the spec page, then you need a software package like auto cad inventor or maybe fusion and this has a built in calculation package.
there are ways to calculate your cog by measuring and weighting  too
is that any good
ricci
2018-9-17
AlphaBravo
Flight distance : 7356 ft
would you mind sharing your inventor file? This would be very handy!
2019-5-9
ricci2
AlphaBravo Posted at 5-9 11:42
hi
If I can find it I will. please bear with me
ricci
2019-5-10
tpsetati
South Africa
Thank you for this! Could you give the distances from the white marker to a physical point on the UAV so we can have a rough idea of where the COG lies in space relative to the UAV?
2022-5-25
