SkySight Aerial
Flight distance : 3312018 ft
Below is an email I received from Hanger relating to their Autopilot app. I thought I would share it on this forum as it appears that this may be an issue with either the DJI firmware or just it's compatability with Autopilot. Either way it is an example to DJI as to how to communicate known issues to customers rather than them having to find out the hard way.
Similar bulletins from DJI would go a long way to raise customers opinions of their very poor customer service.
Current Issues
There is currently an issue with the latest DJI firmware for the Mavic Pro, Phantom 4 Pro and Inspire 2 which causes erratic flight behavior in Autopilot. We do not recommend* using Autopilot with these aircraft types until a resolution has been found for this issue. If you are using firmware 01.03.0200 or below, you should not see these issues.
* It is still possible to safely use Human Flight Control Modes and Waypoint Mode as long as Lost Connection is set to Continue Mission (LCMC).
We will send out another correspondence when this issue has been resolved.
Thanks for your understanding!
Well done HANGER!!
