RedHotPoker
Flight distance : 165105 ft
PhanFran Posted at 2017-3-11 23:20
I have to agree with RedHotPoker. Drones come in different sizes, flavors and categories. Some are more like flying machines with high speed and very fast maneuvering and all kinds of flashy flips and flops, others are the more steady type, designed to carry a good quality camera and make pictures outdoor.
The Phantom most definitely is in this category. It is a flying camera , much more than an aircraft.
And it has no upward sensors. Would be tricky to install these as 95 % of the top is covered by the rotating propellers.
Yes, as a great example, for indoor flight is the Parrot AR Drone 2.0 has an indoor hull, that can accommodate flying it into the ceiling, and it will hover in place, stuck to the ceiling. As well, it will bounce off of lamps and other obstacles without much bother. Pull that hull off and pop on an outdoor hull, and you can fly it quite well in the back yard or in a park, as long as the wind is mild, and you are in control. But it is very limiting, as it flys similarly to the Phantom 3 Standard within its own wifi network. And it's two cameras aren't movable, so you get the same angle of video, no matter how you fly it.
But it's very light, and wouldn't do any damage to something it bumps into, if flying indoors.
RedHotPoker |
