josh crow
WindSoul Posted at 2017-3-12 11:04
looks like an exposure issue. if you had the caption on then you can check the shutter speed and iso in order to make sure you were in auto exposure.if you didint have the caption enabled, then what i see is the entire scene going dark. that can not be due to tapping exposure on the screen because it would expose the tapped area correctly, which is not the case here.
people using filters do lock the shutter speed and obtain the exact results you have presented here, did you use filter aby any chance?
if after that the camera still recorded normally, then i would suspect an inadvertent shutter lock. if camera still records dark, then i would do a reset to default and take it from there.
hi
we havnt got any filters
the AE was on the screen i can remember that
and i used the wheel to move the gimble up and down a few times
but cant realy remember much of the flight ,was concentrating on the ipad screen
thanks |
