+ controller, using ipad with hdmi
1314 15 2017-3-15
wobbles
Flight distance : 547438 ft
hi
is there a adaptor to use ipad pro with + controller using hdmi ?
cheers
2017-3-15
Indio
Flight distance : 303373 ft
Austria
no, an ipad has no hdmi in, you can use only a videomonitor
2017-3-15
DJI-Jamie
Flight distance : 112405 ft
Indio is correct. If you want to have a second screen with your P4P+ RC, then you need an actual monitor with an HDMI input/output.
2017-3-15
Plzi
Flight distance : 1269475 ft
Czechia
DJI-Jamie Posted at 2017-3-15 21:17
Only one monitor/display is active. When connect HDMI monitor display on your device (DJI GO 4) is display black and white and freezes (no live preview).
2017-3-16
wobbles
Thanks guys that is what I needed to know .. cheers
2017-3-16
DJI-Jamie
Plzi Posted at 2017-3-16 01:53
Just to clarify, do you have the dual screen option enabled in the Go app?
2017-3-16
wobbles
DJI-Jamie Posted at 2017-3-16 14:49
not sure where that is tbh ..
2017-3-17
Plzi
Czechia
Where is enabled dual screen (P4P)? I see only: Enable Coach Mode but when i connect Phantom this option is hidden.
2017-3-17
DJI-Jamie
Plzi Posted at 2017-3-17 13:28
If you have a P4P, then it should pop up in the Image Transmission section of the app underneath the channel options. You would have to ensure that the monitor is turned on and connected.
2017-3-17
DJI-Jamie
wobbles Posted at 2017-3-17 10:29
On a P4P+, the HDMI would automatically display the feed when the HDMI monitor is turned on and connected. You would see a message appear in the app that "HDMI is connected". If it's a monitor that can do both AV and HDMI in/out, then make sure your monitor is set to HDMI.
2017-3-17
Plzi
Czechia
DJI-Jamie Posted at 2017-3-17 16:13
I have nothing - no option for second monitor
2017-3-19
DJI-Jamie
Plzi Posted at 2017-3-19 13:51
It would only appear if everything is turned on and connected to the controller. The option does not appear otherwise. Just to make sure I'm on the same page, you have a P4P and not the P4P+, correct?
2017-3-20
Plzi
Czechia
DJI-Jamie Posted at 2017-3-20 11:00
Yes, I have P4P and HDMI out modul in the RC.
2017-3-20
Plzi
Czechia
2017-3-20
DJI-Jamie
Plzi Posted at 2017-3-20 13:11
Based on your picture, it doesn't look like anything is connected. Have you tried connecting everything up to see if the option appears?
2017-3-20
Plzi
Czechia
DJI-Jamie Posted at 2017-3-20 15:00
Yes, I tried connect Phantom P4P (firmware Phantom  01.03.0418, RC 1.4.0.0 with HDMI modul out) and I did not show any options for enable this function (first and second display switchon together).
2017-3-22
