fansa84fe8a4
I've been hesitant to try the possible 'brickware' version 01.02.0602 as the report is "You can't go back if it doesn't take." Bad form.
I've programmed enough microprocessors in the past to know that sometimes the internal EEPROMs will not take a write or erase correctly a first or second time. Sometimes another run will break it completely. I did a flash trigger where you load the micro SD card with a new bin file, put it into the device, turn it on, and nothing! Black screen forever. Prior times it worked fine, but the last time it cost me $85 for a new board and it worked.
Even running some testing programs on memory cards can show the differences between the same brand/model where the data stream dips or jumps on one card and smooth on another. Memory can be very volatile, and not always in a good way.
